Question about Rival 38601 Smart Pot 6-Quart
Green light is blinking, but I am unable to trun the power on.
The green light is blinking, but I am unable to trun the crock pot on or off.  The light just keeps blinking.
  • 5 more comments
  • Georgew Oct 30, 2007
    After about 30 mins or so the crock pot truned it's self on and started cooking.  Problem solved.  Just wait a little bit.  maybe you might have gotten something wet inside when you were cleaning it like I did.  I think.
  • Anonymous Jan 28, 2008
    Used this once and it worked fine. Used it again, came home - and the food was cooked, but it was stone cold. Tried to use it today and light either blinks or stays solid and no cooking options turn red ... so I keep hitting buttons until HIGH 6 HOURS lights up .... then it actually TURNS ITSELF OFF after about 3 or 4 minutes!!!! I can't cook anything!!! This is crazy! My email is barnworks@att.net if anyone knows what's going on. I think I have a defective unit. PLUS: that day it was stone cold, shouldn't it have switched to WARM and not turned itself off???
  • Anonymous Mar 25, 2008
    I have a similar problem with my 6 qt rival crock pot that I got at Costco. I bought it in 2003 and haven't used it that much. Recently, the unit turns itself off (all the red lights are blinking) after just a few minutes. Usually, I can reset it and it works fine. As I was cooking a big church dinner last week, it totally stopped working. The lights all blinked and I couldn't get the timer set. When I called Rival, I was told that my warranty was up and I'd have to buy a new unit even though I only need the part with the timer on it. The Rival person suggested, this was a safety feature and that there must be something wrong with my power. Hard to believe, but who knows. I tried turning it on a few days later and at least it looked like it was going to work. I may give it a try once again
  • Anonymous Apr 15, 2008
    My Dad is having the same problem, I sent it to him as a gift, he's 86, when he told me he was going to try using his old pressure cooker, so I had Target mail him the same rival one that I have been using for years. He's used it twice, no problem. He just called and the power won't come on just a blinking light. Is there a hidden reset button anywhere? I'm @ work so I don't have the pot here in front of me to look for myself.
  • Anonymous Nov 16, 2008
    MIne is a Crock Pot Smart-Pot and it is behaving the exact same way. It simply tuns itself off, unexpectedly. We got this as an X-Mas gift 2 years ago. Only started using it 2 months ago. I do not think the warranty will cover it. Was there a recall or something? fdiciero@miranda.com
  • Anonymous Mar 13, 2009
    If the unit is left unplugged it takes a number of attempts to get the programming to work. As It gets older it takes longer and longer. I have found by leaving it plugged in for 30 minutes before I attempt to set the cook time cuts down on the number of attempts to get the settings going.
    The usual response is that the 4 hour high setting will just flash on then immediately off again. After a number of attempts (up to a hundred or more) the 4 hour setting starts to stay on longer. Eventually the four hour setting stays on and I can cycle to the 6 hour setting. It takes fewer attempts to get this setting to stay on. Similar techniques allow me to eventually cycle through all of the settings. Once this has been done all the settings are accessible with a single push of the cook time button. Be prepared to spend fifteen minutes getting the pot to function properly. I bought two of these units and gave one to my daughter. Her's does the same thing.
    Rival, of course deny knowledge of this common problem and suggested I purchase a new pot since this one is out of warranty. Thanks for playing but I will look for another brand the next time!
  • David Empson
    David Empson Feb 13, 2017
    My 2011 crockpot sccpvp700-s-060 has no lights flashing. It takes about 2 Watts and you can just hear it humming (use a portable AM radio and you can easily hear the interference). The capacitors, transistors, thermister, thyristor triac, resistors, diodes led's tested fine and there's a healthy 5.1v powering the microcontroller. So either the latter has failed or there is a short or open circuit somewhere or I missed a small smd fault. Shame crockpot don’t have circuit diagrams on their website or even sell the electronic modules.It's a shame to throw away a new looking item that 99% works.
    Leaving on for 1/2hr or pressing both buttons in for 1 minute didn't do anything.
  • 3 Answers
Rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
Posted on Aug 31, 2010
  • RenoTW Nov 19, 2010
    It worked!!
  • Jennifer Anderson
    Jennifer Anderson Nov 19, 2014
    You saved our potluck!
    President:
  • 2,712 Answers
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
4 Suggested Answers
  • 4 Answers
SOURCE: rival 3860 crock pot lid neededr
http://www.crock-pot.com/
They have all the parts people have mentioned
Posted on Dec 30, 2007
SOURCE: Corningware crock pot
for replacement parts information on Corningware products, you may call toll free (in North America) 1 800 999 3436.
Posted on Nov 23, 2008
SOURCE: Need owners manual for Rival Crock Pot BBQ Pit
Here is a copy of the manual.
http://www.fenwayfaithful.com/stuph/BBQpit.pdf
Posted on Jun 25, 2009
I removed the nut from the bottom of my rival crock pot model 3100/2. How do I get it back on?
If you cannot get it back on, take the nut to Home Depot for a new on. Maybe the nut is stripped.
Nov 18, 2015 | Rival Crock Pots & Slow Cookers
3 lights blinking on my sccpvc709-s
Someone suggested there is moisture under the pot. Use hair dryer to dry it up.
Other suggestion is if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state
The instruction manual does not say anything. But you can find the Crock Pot number to call.
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-crock-pot-Site/Sites-crock-pot-Library/default/v1397907098387/documents/instruction-manuals/SCCPVC709-S_43_38491059.PDF
Apr 20, 2014 | Crock Pots & Slow Cookers
How do you clean corning ware?
If it's too messy, let a bunch of warm soapy water soak in it a few hours or overnight.
Use the green scritchee pads with elbow grease.
or
Dishwasher.
Next time buy the crock pot liners that make clean up quick! :-)
Feb 20, 2012 | Crock Pots & Slow Cookers
I have a Dark Green liner and the outside color is white with green Ivy. The model # is 3745. Mine is cracked, and want to know what the price of a new pot, compared to purchasing a whole new unit?
I actually have that very same crock pot and my dark green crock and solid glass top are in perfect condition, but the electrical cord is starting to tear and expose the wire. I think it's doing this because the cord isn't underneath the unit and is on the very back. Is there anyway to find a new electrical base?? I LOVE my crock pot, especially because it's the perfect size, nice and big for a pot roast. Does anybody want to sell their electrical base? or I'm wondering if should try and sell my dark green crock and glass lid? Is there anyway to buy another electrical base???
Mar 12, 2011 | Rival 3745 4.5-Quart
Searching for pasta sauce recipe
Barbara....I understand -- I panicked to day when I couldn't find my CROCK-POT recipe book for my Chicken Cacciatore recipe. I think I have that same recipe book -- my CROCK-POT is avocado green. Tthere are two recipes for spaghetti, but I'm assuming that you want the "Italian Meat Sauce" recipe. If not, let me know and I'll send the other one.
Crock Pot Italian Meat Sauce
1 cup chopped onions
1 – 1 ½ pounds ground chuck, browned
2 cloves garlic
1 large can tomatoes (28 oz)
1 6-oz can tomato paste
2 stalks celery with tops, chopped
2 teaspoons salt
3 teaspoons dried oregano
¼ teaspoon dried thyme
1 bay leaf
Put all ingredients in CROCK-POT. Stir thoroughly. Cover and cook on Low for 10 to 12 hours. (High: 3 to 5 hours).
Elizabeth
Feb 21, 2009 | Rival 3100 3.5-Quart
Our 38501 5 quart crock pot liner just busted!
I have a crock pot and the crock broke it was the one with the Ivy on it and had the green oval crock I'm not
sure if it is a 5 or 5.5 qt. I need to replace the crock how much would a new crock cost?
My name is Carol Howard my address is604 Sheridan St.Chenoa,Illinois 61726,my email is tia1552@yahoo.com please email me back and let me know where and how much it would cost to buy a new crock.Thank you Carol Howard I wait to receive your email
Jan 24, 2009 | Rival 38501 Smart Pot 5-Quart
Rival Crock Pot LIner replacement
I have a round, forest green stoneware liner for a Rival crock pot. The liner has no divider. The liner has no chips or cracks. Sorry but I cannot remember to which model number this stoneware liner fit; but I can tell you that the Rival crock pot I had was either a 5 to 6 quart and it fit a plastic lid.
Feb 10, 2008 | Rival 3145 4.5-Quart
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Dec 21, 2007 | Rival 5865-W 6.5-Quart Slow Cooker
Rival 38601 Smart Pot 6-Quart Logo
7,638 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
