Question about Mr Christmas Holiday Carousel Animated Lighted Musical Figures Carols
The plug in on the carousel has been damaged
Plug in on the carousel is missing
Kodak carousel 750H slide projector power cord missing
Detatchable power cords for KODAK Carousel Slide Projectors can be purchased from: www.micro-tools.com
or: www.vinevalleyimaging.com
Good Luck!! jim
Sep 13, 2013 | Kodak Carousel 4600 Slide Projector
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
A page from the instruction manual was missing and now i have no idea where the music box goes. Where does it go?
The directions for installing the music box are in the Annex Instructions.
I have scanned the Instructions and the Annex instructions. You can view and download them from here:
The Enchanted Carousel Instructions - Wrebbit
https://docs.google.com/open?id=0B5flfeMskegmYWVlZTZjODYtMGU1ZS00ZDRmLTg3YTEtMTI4MzBkZTFhYmNi
The Enchanted Carousel Annex Instructions - Wrebbit
https://docs.google.com/open?id=0B5flfeMskegmYWZkYWI5NGEtOWEyOC00OTRmLTg2MDEtNWUzNWU1NzM2MWJh
Aug 05, 2011 | Wrebbit Enchanted Carousel Wrebbit 3-d...
We have a Gemmy airblown carousel with four figures inside. It will only partially inflate. We have unzipped everything and untwisted everything. The bottom inflates and part of the top but nothing in...
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
Nov 29, 2010 | Carousel Airblown Inflatable Christmas...
I have a Yamaha carousel d.v.d. player and the carousel is jammed. i cannot load or eject. how can I unjam?.
If you are technically inclined, you may be able to fix this. Any discs not in the carousel correctly must be CAREFULLY removed - NO FORCE. Inspect the carousel for damage. Look at the disc pick fingers and see if they are broken. Remove all discs and run the unit to see if it goes 'home', disc one. With the discs in, you take the chance it cannot run right and damages more discs.
I use the clear cover disc from DVD stacks as fake discs. I can see everything the machine does through the clear plastic.
Mar 29, 2010 | Audio Players & Recorders
IBM Autoloader 36232sx error code A027 & A060
A0= Error occurred during carousel movement (position not found). Could be caused by a carousel motor power issue, a missing or misaligned cartridge carrier, an obstruction, or an unexpected cartridge in the carousel path.
I also advise you to update the FW of the loader.
Are you having tapes get "Stuck" in the unit?
Feb 01, 2010 | IBM Computers & Internet
One click carousel missing
back up your contacts and do a full reset on your phone.
Apr 15, 2009 | Samsung Rant Cell Phone
A cd has gotten stuck in my Sony 5 cd/dvd carousel player. Appears that the label on the CD had gotten soft (sticky) and when the carousel rotates it stays stuck underneth the top while the carousel moves...
As long as the cd hasn't caused any other damage to the electronics or mechanics of the player, it should be an easy fix. First, open your carousel then unplug the player to avoid shock. Remove the top lid of the player via the screws on the exterior holding it in place. From there, the stuck CD should be right there for you to reach in and remove. Hope this helps!
Mar 24, 2009 | Sony CDP-CE375 5-Disc CD Changer
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Mr Christmas Holiday Carousel Animated Lighted Musical Figures Carols Logo
83 people viewed this question
Top Mr Christmas Home Experts
john h
Tom Chichester
Are you a Mr Christmas Home Expert? Answer questions, earn points and help others
