Question about Pentax Cameras
Pentax kr ,cant change the language.camera freezes
Pentax kr cant change language. camera freezes
Will lens from a sf1 fit the newer models like the Kr or better
Yes. The new digital model cameras will accept the older K-AF lenses.
Mar 01, 2013 | Pentax Sf1 35mm Slr Film Camera 35-70mm...
Change language to english on pentax optio VS 20
Follow the instructions in the "Changing the Display Language" section of the manual (begin on page 183 in my copy). If you need a manual, you may download a copy here.
Jan 12, 2013 | Pentax Optio VS-20 Digital Camera - White
What kind of lenses should I buy for my new Pentax Kr? People tell me to buy new digital lenses. What is the real scoop on lenses for this camera?
Newer lenses tend to be sharper and lighter than older lenses, and with better optical characteristics. Some digital-only lenses are also designed for the smaller sensors of some digital cameras, allowing for further reductions in size and weight. In general, lenses designed for film cameras will work with digital cameras.
If you already have Pentax-mount lenses, by all means continuing using them if you're satisfied with the results.
Jul 20, 2012 | Ricoh Cameras
I have a Pentax K10D from the time they were first sold. I have not installed any firmware as not very technically talented. Have recently bought a Sigma 120-400 zoom.( no zooms of this range from...
Only Pentax DA and FA J lenses and D FA/FA/F/A lenses having an "A" position on the aperture ring can be used with this camera.
The lens you have is HSM DG
Jun 10, 2017 | Pentax Cameras
I have a Pentax K100D and occasionaly when I push to button to take a picture it does not work. I have to turn off the camera and then try it again. It is in Auto mode. Is this a "fixable issue"...
When this happens, does the battery indicator show no battery power? If so, this is a common issue and most owners check the battery indicator first before snapping and if it shows empty, they do the "turn off/on" routine. The newer cameras (K7, Kx, Kr,K5) do not seem to have this problem.
Nov 11, 2010 | Pentax Cameras
Hey i have a pentax camera and the language is ducth or chineese..i cant speak either of the two..so i am asking if you could please help me put it in english so i can understand what i am doing..thank you
Turn the mode dial to the screwdriver-and-wrench icon and turn the camera on. Use cursor-left/right to select the first tab, use cursor-up/down to select the fourth item on the menu, and press the OK button. Select the desired language and press the OK button.
Aug 11, 2009 | Pentax Optio 60 Digital Camera
Pentax Espio 115 exhibits an H3 error and camera does not work. Sometimes it's a H2 or 1 error. What does this mean.
RE: Pantax ESPIO 115
Dear Sirs,
I bought the Pentax espio 115 Camera in Tokyo and have been well using but it was out of order suddnly .I could find in Lcd panel appeared <H3 mark>and not worked after.
Kindly let us know as quickly as possible what should I do shoot the trouble..??!
Awaiting your kind response.....
Thank you.
Mr.U.S,Yu?South Korea
email:elvisu@lycos.co.kr
Mar 21, 2008 | Cameras
Cameras Logo
22 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
