Question about Hoggan Sprint UBE Sprint UBE
SPRINT UPPER BODY ERGO DIM DISPLAY
WHAT TYPE OF BATTERIES ARE USED IN THE SPRING HOGAN UBE?
Just replaced battery in my Conair WW87 scale and the numbers now do not display fully. Broken up
Recheck the battery connections and check the batteries, this type of display most times means low battery voltage.
Sep 12, 2016 | Conair Weight Watchers WW-87 Body Fat...
2001 buick century torque prints for haeds on up
the 3100 specs
Type: Bolt Dim: Length: Head: Hexagon Grade: 37 Ft-Lbs 444 In-Lbs 50.17 N-m Connects: Cylinder Head To Engine Block Years: 1998-2001 Vote Record: Vote Note: 3100 - Head Bolts - 2 Steps: 37FtLbs; +90deg
12 Ft-Lbs 144 In-Lbs 16.27 N-m Connects: Exhaust Manifold To Cylinder Head Years: All Vote Record: Vote Note: 3100 - Exhaust Manifold to Cylinder Head
Type: Bolt Dim: Length: Head: Hexagon Grade: 9.58 Ft-Lbs 115 In-Lbs 13 N-m Connects: Intake Manifold To Cylinder Head Years: All Vote Record: 0/1(0%) Note: 3100 - Lower Bolts - 2 Steps: 5 FtLbs; 9.58 FtLbs Here are the head bolt torques for a 3.8
37 Ft-Lbs 444 In-Lbs 50.17 N-m Connects: Cylinder Head To Engine Block Years: 1999-2005 Vote Record: Vote Note: 3800 II - 2 Steps: 37FtLbs; +120deg
13 Ft-Lbs 156 In-Lbs 17.63 N-m Connects: Exhaust Manifold To Cylinder Head Years: 1999-2005 Vote Record: Vote Note: 3800 II - Exhaust Manifold to Cylinder Head - NOT FRONT 2
7.42 Ft-Lbs 89 In-Lbs 10.06 N-m Connects: Fuel Rail To Intake Manifold Years: All Vote Record: Vote Note: 3800 II - Fuel Rail Mounting Bolts 2.25 Ft-Lbs 27 In-Lbs 3.05 N-m Connects: Idle Air Control Valve To Throttle Body Years: All Vote Record: Vote Note: 3800 II - Idle Air Control Valve to Throttle Body Type: Bolt Dim: Length: Head: Nut Grade: 11 Ft-Lbs 132 In-Lbs 14.92 N-m Connects: Intake Manifold To Cylinder Head Years: All Vote Record: Vote Note: 3800 II - Intake Manifold to Cylinder Head Bolts/Nuts
7.42 Ft-Lbs 89 In-Lbs 10.06 N-m Connects: Intake Manifold Plenum To Intake Manifold Years: All Vote Record: Vote Note: 3800 II - Intake Manifold (Upper) to Lower Manifold Type: Bolt Dim: Length: Head: Hexagon Grade: 14 Ft-Lbs 168 In-Lbs 18.98 N-m Connects: Knock Sensor To Cylinder Head Years: All Vote Record: Vote Note: 3800 II - Knock Sensor
Jul 24, 2016 | 2001 Buick Century
Why does my 2d mag flash light stay dim
Check for corrosion at the bulb, or the spring or the switch. This happens sometimes when batteries leak internally.
Oct 20, 2014 | Other MAG-2D - Maglite Small Head 2 D-Cell...
Control panel buttons not working
if your sistem ( has batteries, replace by new ones, but clean the contacts batteries from dirty, oxide, etc use contacts cleaner and tight the spring with pliers)>
2) tight the ribbon cable inside the display board.
3) tight and clean the upper and lower connector from display.
4) adjust the REED swtich. see the diagram attached.
Oct 18, 2013 | Precor 9.21 Treadmill
Panel lights dim
1) Replace the batteries by new ones, same type and the o.k polarity.
2) clean the contacts batteries, with c. cleaner
3) Tight the ribbon cables, for good contacts keypads.
4) Tight the connector from upper board vs lower board very well
5) Adjust the REED swtich very well, clean it, and tight the connectors.
Nov 27, 2012 | Nordic Track Nordictrack C 2300 Treadmill...
I have a Briggs & Stratton Sprint 3.75 hp lawnmower and it seems the cord is pulled almost all the way out and won't retract. How will i know if it is broken? or should I be able to wind it back up...
You should be able to Fix this yourself if your a fair garage tinkering mechanic. However...I need the engine and type number off of the engine to get you parts information. The spring is broken in your recoil. It is a matter of removing the air shroud, taking off the pulley / spool and changing the spring.
http://www.ehow.com/video_2328977_how-install-lawn-mower-starter.html
and how to tension the spring:
http://www.ehow.com/video_2328961_how-tension-lawn-mower-starter.html
There are 2 different types of springs used so having your engine model / type number is important so that you can get the right spring. One of the 2 part numbers is: 390066
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Briggs & Stratton Briggs Stratton...
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
Replace coil spring
You have to remove them - that "block" is the upper strut-to-body mounting section and serves as the upper seat for the spring as well as the anchor for the top of the strut. You need to take those four 17mm bolts out, as well as the rear upper sway bar bolt, the upper control arm bolt (at the top of the hub), and the bottom bolt on the strut, where it goes through the lower control arm. You'll then have to compress the spring enough to take the bolt out of the "block" (it goes through sideways, and I believe is 19mm on the bolt head as well as the nut). At this point, you can slide the spring/strut out of the block, decompress the spring, pull out the strut, and install a new spring over the strut. Recompress enough to get the top of the strut visible through the anchor bolt hole in the block, rebolt it, decompress the spring, and reinstall the assembly in the car. Usually when you go to reinstall it, the bottom of the strut is not angled quite right once the top four 17mm bolts are back in and the block is secured to the body. I put a large screwdriver through the lower strut bolt hole at the bottom of the strut and use that to turn it, or I grab the weld near the bottom of the strut with large ChanneLock pliers and turn it until it's aligned with the control arm properly. Once it is, put the lower bolt back in, rebolt the control arm and sway bar, and you're good to go.
Note - this job will not affect alignment specs - you don't remove any bolts used in aligning the car, so that's not a concern when doing this repair.
Apr 20, 2009 | 1999 Audi A4
Hoggan Sprint UBE Sprint UBE Logo
29 people viewed this question
Top Hoggan Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Hoggan Exercise and Fitnes Expert? Answer questions, earn points and help others
