Question about Fossil FS Watches
CHANGE TIME ON ELECTRO TICK
CHANGE TIME
Timex electric watch not running
Hi Mark,
It appears to be a battery problem. Have you changed the battery recently? How have you checked the battery? I suggest you check the battery's voltage, even if it is a new, replaced battery.
You need to be sure the battery is not the problem before looking elsewhere.
Need more detail if this does not help, including the model of watch. Also how long has this problem existed, and when did you notice a change - was there a specific time/event?
Feb 01, 2014 | Timex Watches
Watch stopped after changing time
It may just be a coincidence that the battery is dead at the same time you changed the hours
Sep 19, 2013 | Nixon Watches
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
Please stop telling people Rolex watches don't tick.
Yes, absolutely correct , all automatic watches tick and the fake Rolexes just tick a bit slower so it is more visible.
Oct 08, 2012 | Rolex Watches
How do I unlock settings (general, user, exercise)?
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Jul 26, 2012 | Polar Electro RS400 Watch
How do change the date on my citizen divers watch
Hope this will helped you fixing the time of your Citezen divers watch. Just foolow the instruction below.
Change your Citizen watch's time zone without actually moving the clock hands. On the digital display, change the city that displays on the watch, which sets the time to the different time zone. The Citizen also has a calendar, timer, chronograph and LED lights. Since it is an Eco Drive watch, it is solar powered so you never have to replace the batteries unless its backup power source dies.
Difficulty: Easy Instructions
  1. Pull the setting knob (crown) out one "tick" for setting mode.
  2. Set the mode hand to "WT-S."
  3. Pull the crown out one more "tick."
  4. Press the top button on the right side of the watch for the city setting mode.
  5. Press the lower button on the right side to "SET" the city.
  6. Turn the crown to select a different city, which changes the time zone.
  7. Push the crown all the way back in to finish setting the time.
Thank you for using Fixya.
Feb 21, 2011 | Citizen Watches
Watch tick much faster
You have to clean hairspring. Unless the hairspring is spotless, there is no way the watch will keep time. Make sure hairspring coils are even and not touching. Rate me, please.
Apr 13, 2010 | Timex 27191 Wristwatch
Backlight on DW6900
You cannot change the light. It is an electro-luminescence layer behind the display. It is something like a large LED. They are designed to not be very bright to save battery life. I have a number of Casio watches. They are all not very bright. Also the non silver background type watches tend to be much darker than the silver background with black symbols.
Jan 29, 2018 | Casio GShock GShock Youth Culture Theme s...
My watch stops and starts - for example I will wake up in the morning and the watch will be ticking but the time will be 6 hours behind the actual time
from experience this generally happens when the battery is low, the tick will appear normal however the time does go round in sync with it. Replace battery would be my first point of call
Oct 07, 2009 | Tag Heuer WK1111BA0317 wristwatch
Second Hand
smash it with a hammer
Feb 10, 2008 | Fossil CH2332 Wrist Watch
Watches Logo
235 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
