Question about Digihome LED19913HDR 19" LED TV 1366x768, Freeview
Digihome tv alarm comes on at 3am
The power light bleeps at 3am
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Hi i have digihome tv but when plugged in there is nothing
First plug a other thing in the plug on the wall if it comes on then you know it's the tv power is a problem it could be that the power supply's has popped also there should be a button on the side of the tv some ware press it in or on make sure there
May 02, 2014 | Digihome Televison & Video
I have a 22" digihome LCD TV with built in DVD. At 3am every morning the DVD activates and buzzes away. The screen doesn't come on but there is a loud click as the speakers activate. How can I stop this...
3am is the freeview box update time it will do this every day at 3am the loud click you hear you should not hear it but it may be the update switch that turns the tv out of standby for the freeview to be updated its a different switch that turn this on and may be sticking.
Oct 02, 2013 | Digihome LCD TV
Digihome tv
sounds like the sound board is not getting the proper power. would check the power board for worn out capacitors or leaking ones. cheap fix if you know how to use a soldering iron.
Sep 07, 2013 | Televison & Video
The tv is going on automatically at 3am. How do I get rid of this
The exact procedure depends on the model, however it sounds like an alarm is set. Most of these tv's have to be left in stand by mode for the alarm to function. Take it out of standby mode, or better yet shut the alarm off. Find this via the clock button menu.
Jan 01, 2011 | Philips Televison & Video
Door ajar light - power windows and alarm
you may have a broke wire in the door harness
Jul 16, 2009 | 2002 Ford Explorer
Television goes on at 3am each morning. Can't
may be u have set 3am time to on it
Jul 12, 2009 | Televison & Video
Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
nikunj@qool-point.co.kr
Nov 17, 2008 | Liebherr Refrigerators
Machine emits continuous high pitched bleep and power light flashes blue/red
If working OK, probably means that the temperature alarm goes off because is getting hot the PC. I suggest to check why is that happening. All fans working OK? is the CMOS temperature alarm set too low? check your motherboard instructions booklet- It will tell you what the beeps mean probably in the last pages. Good luck
Sep 28, 2007 | Sony VAIO PCV-RX511 PC Desktop
Digihome LED19913HDR 19" LED TV 1366x768, Freeview Logo
Top Digihome Televison & Video Experts
john h
David Hoff
Are you a Digihome Televison and Video Expert? Answer questions, earn points and help others
