Question about HP ScanJet 5370C Flatbed Scanner
Precision scan Pro Software
Fix for Sorry, cannot find required Library, please reinstall application."
3 Suggested Answers
SOURCE: Precision Pro 3.1
You may want to try this web page that tells you how to get the HP 5300C
working in Vista. It works fine on HP 5400C as well.
'Tutorials - How to get your HP Scanjet 5300c working in Windows Vista'
(http://www.pixel2life.com/publish/tu...windows_vista/)
Posted on Feb 22, 2009
kamal1984
  • 1383 Answers
SOURCE: When I try scanning something a message comes up
remove your old scanner drivers and reinstall again after restarting the computer.
Posted on Apr 16, 2009
Precisionscan
Sounds like you have a problem with a DLL "Dynamic Link Library" for whatever program you're trying to use. Most likely it's been corrupted possibly by a virus or bad sector on hard drive or a file that mistakenly got deleted or any other number of things. I have had this problem before but only with the operating system (Win XP pro) never with another program. In my experience the only really good way to fix it is to re-install the program. Best of luck. Definitely run virus scan to check your files. Also you may want to try fixing in safe mode first if it's an op sys file that is corrupt or you can try system restore Found in start panel/accessories/system tools. If it's a program other than your operating sytem I would just uninstall it and then re-install it. Hope this helps. P.S. Microsoft will stop supporting Win XP next month (April 2014) no more updates etc. You might just want to upgrade to a newer version of windows.
Mar 21, 2014 | Microsoft Windows XP Professional
Adobe Acrobat 7.0 Pro Error
Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue. These products were released more than seven years ago, do not run on many modern operating systems, and are no longer supported.
Download the New Copy of Acrobat and activate it with the new serial Number .
Click this Link CS2 downloads
Apr 22, 2013 | Adobe Acrobat 7.0 Professional
I'm using Autodesk sketchbook Pro 2010 and I frequently get a Micreosoft Visual C++ Runtime Library Error. It reads Runtime Error Program: C:... This application has requested the Runtime to terminate in...
Possibly you may need to reinstall your program. Or you could go into your configuration settings and resetting your configuration to factory standards, then change one thing at a time in the configuration until you find the setting that is causing your operating system to act up.
Mar 29, 2011 | Autodesk SketchBook Pro 2010
Scanner shut down improperly and will not reboot because message says check Confirm all other Dimage Software is closed. I have done everything I can think of including reinstalling software and removing...
Please restart PC.
If it cannot be started up after restarting PC, delete two files shown below:
/Library/Application Support/DS Elite5400 2/MFSLibInit
/Library/Application Support/DS Elite5400 2/MFSButtonCheck
/System/Application Support/DS Elite5400 2/MFSLibInit
/System/Application Support/DS Elite5400 2/MFSButtonCheck
Jan 10, 2011 | Konica Minolta Dimage Scan Dual IV Film...
Ereader library won't open
Hi.
If you're using the Windows Operating System, the issue may be caused by the Data Execution Prevention feature in the Windows Operating System or if certain folders used by the Reader Library Software are corrupt. Please click on the below link and select the desired Operating System to get the troubleshooting steps.
If the issue persists, uninstall the Software and restart the Computer.
Next, disable all the active Software's (Firewall, Anti-virus, etc) in the Computer and reinstall the Software.
Also, please ensure to check the "Launch Software" at the end of the installation. This should resolve the issue.
If you're using the Macintosh Computer, uninstall the Software as per the below mentioned steps:
First, click "Go" and then click "Applications" in the Main menu.
Next, in the "Applications" folder, in the right pane, double-click on the "Utilities" folder.
Then, in the "Utilities" folder, double-click "Terminal".Now, in the "Terminal" text window, type "sudo /Library/ebookLibrary/uninstall-ReaderLibrary.sh". There is a required space between sudo and /.
Next, please press "ENTER" on the keyboard. A confirmation message will appear. Please enter your Password or leave blank if you do not have a user account password.
After the Password has been entered or left blank for no password, press ENTER. You will receive the message that the Reader Library Uninstall is finished.
Now, please click "Terminal" and then "Quit Terminal" to exit the Terminal application in the Menu.
Finally, close all other open windows.
Now, restart the Computer and reinstall it.
Note: Ensure that the Reader is not connected to the Computer while performing any of the above mentioned steps for Windows/Macintosh Computer.
Feb 25, 2010 | Sony Reader Touch PRS-600
OS: Windows XP SP2 .NET 3.0 Product: Pinnacle PCTV HD Pro Stick Hardware: Dell Latitude E6400 - 4Gb Ram Error PMCLoader.exe ''Application has generated an exception that could not be handled'' I get this...
check the requirements of the your application make sure the requirements of that application is properly installed, if not reinstall the requirements and delete the registry keys for PMCloader.exe or Pinnacle and reinstall the pinnacle software...
Feb 23, 2010 | Office Equipment & Supplies
I have a Photosmart 3310 that I use with a MacBook Pro. I have scanned before but all of a sudden I can't scan. I have tried restarting, reinstalling software, restarting Photoshop. Help!!!
Don't reinstall Photoshop any more, that's not necessary. Just leave PS alone.
Have you done anything, like upgraded the operating system?
Try a couple of things. We'll start with the easiest.
Try scanning directly from the "Preview" application - this works really well.
Open the application "Preview"
Go to the File menu, and then "Import from Scanner" - hopefully your scanner shows up ...
This is a great way to scan.
If your printer/scanner does not show up when you do this, you will need to (sorry to say) re-install the software for the printer. But you said you already did that!
I'm going to suggest, if you haven't already, to go to hp.com and find your printer and download the package of software for it and reinstall that way - they periodically update the software. HP printers are a bit fussy about this, so reinstalling the "latest" HP software is definitely worth trying.
Hope that helps!
For PA system troubleshooting and general assistance with conference audio, visit rexark.com
Jan 08, 2010 | HP Photosmart 3310 Printer
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
Photoshop element 5.0 trial download error
Have you reinstalled the application has the trial ceased? I f ll of these are yes no one can help you but the sofware company ....uninstall the programme or buy the full version.
Sep 15, 2007 | Computers & Internet
HP ScanJet 5370C Flatbed Scanner Logo
19 people viewed this question
Seeker5211
Seeker5211
