Question about Dell A215 Computer Speakers
The speakers do not sound good,
What type speakers can I by for a Dell, and how do you hook them up ?
    Scholar:
  • 124 Answers
I bought cheapy speakers for my computer and they sound amazing ... like $20 at Target. :)
However, if you are looking for decent sound, here is a review of some top speakers.
Mine came with detailed instructions in the box, which amounted to - plug into the electric outlet on the wall, and then put the green plug into the green dot on the back of my computer. Super easy!
Posted on Jun 14, 2009
I have a standard old Dell desktop, I hooked up a set of Creative T7700 speakers, they worked wonderful for about twenty minutes and the quit all together. I re-hooked the single line back to the flat...
By the single line I assume you mean the green line out cable and you have connected this to the sound connector on the monitor, so that you have the Dell computer using the monitor speakers?
The problem may be down to the sound chip on the Dell conflicting with Creative labs speakers, it may not support the 7:1 sound. You can try updating the Dell sound drivers, however Given the problem, I'd invest in a pci soundcard and hook the speakers up to that, or look at an external soundcard
Jul 28, 2011 | Computers & Internet
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
Can't get speakers to speak
change the defualt playback device to internal speakers. the option is available in the sound properties under playback
Jan 08, 2010 | Dell A215 Computer Speakers
My Dell AS501 does not produces sound. I have
make sure the power is hooked to the back of the monitor, and that the speakers are hooked into it. make sure it is switched on and volume is at 50% or higher. if it still doesnt work, try hooking an mp3 player to the speaker jack. if they work, its the computer. if it doesnt work, replace the speakers.
Dec 12, 2009 | Dell AS500 Sound Bar Computer Speakers
I have a dell 3300mp projector hooked up to a dvd player and I cannot get any sound. What do I do?
sound form your projector? or from your speakers? set the volume of your projector to maximum. then check your connection cables if good your speakers if working. check all your component have pwoer supply.
Oct 28, 2009 | Dell 3300MP Multimedia Projector
I have dell speakers hooked up to my dell pc but NO sound.
  • Ensure the connection first if the connectors are hooked up to the correct port.
  • check if the speaker is receiving the power there should be an indicator lit up
  • If you have an integrated sound card make sure they are not disabled in BIOS.
  • Then check if the sound drivers are properly installed.
  • check the volume control to ensure if mute is checked(uncheck it) also ensure the volume level it needs to be set to a level so that it's audible to you.
  • Do check the speakers with another devioce to ensure the speakers are fine and working.
  • FOR MORE SPECIFIC INFO PLEASE PROVIDE THE MODEL AND BRAND DETAILS OF THE PC AND SPEAKER AND OS
Feb 21, 2009 | Dell Audio Players & Recorders
How do i reinstall my dell speaker? i deleted them off cp. my bad
The speakers are not the sound device, the sound card is. You ust select the sound device that is installed in the computer. If you PC is a Dell, go to Support.dell.com and enter your service tag in the downloads section. download the latest audio driver for your PC and it should reset everything to the correct parameters.
Good Luck!
Jan 05, 2009 | Dell A215 Computer Speakers
Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Feb 28, 2008 | HP JBL Platinum Computer Speakers
Can I hook up dell speakers to a HP
i think your have problem with sound card,
otherwise dell peakers works with hp.
you should see for updated driver for your sound card.
Oct 31, 2007 | HP P5302M Computer Speakers
Dell A215 Computer Speakers Logo
41 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
