Question about LG Washing Machines
Wf n7039np preasure switch
SHOW SPRINGS SCHEMATIC ON PREASURE SWITCH
Are you talking about a wiring diagram or an exploded view of that switch?
Jun 08, 2013 | Craftsman Air Tools & Compressors
Where is the air conditioner sensor in ford fusion
There are a few sensors or as i call them switches, the low preasure/cycling sw. and the high preasure switch (sw.) theres a temp sensor inside the heater box on the evaporator core, the switches are located on the lines one is on the suction line and the other is on the high preasure line.
Jun 26, 2010 | 2006 Ford Fusion
Whats an engine switch for a oldsmobile 1983 cutlass
there are a few switches for the engine, the coolant temp switch, this controls the temp gauge on the dash, then the coolant fan switch that turns on the fans when engine is hot and then the oil preasure switch that lights the oil light on dash when oil preasure is low, hope this helps.
May 28, 2010 | 1983 Oldsmobile Cutlass Supreme
AC PREASURE IS GOOD BUT COMP WANT COME ON CHANGED PREASURE SWITCH NO HOT POWER TO SWITCH
Check the a/c compressor relay.Remove the relay and use a jumper wire between terminals 30 and 87,if compressor comes on then the relay is bad or the high pressure switch is bad.
Aug 03, 2009 | 1996 Lincoln Town Car
1999 Silverado a/c problem
check your high preasure switch,check your preasures,if your preasure on the high side if it high the preasure switch is protecting your compressor,to be honest if your not trained in this you need to take to some one who has a license
Jul 27, 2009 | Chevrolet Tahoe Cars & Trucks
ADMIRAL LSD2615HEZ
Pls.check the unit if does have a low and high preasure switch,posible the system is in the low preasure that switch to cut off the unit.check system preasure,if low preasure found,you need to recharge the system.
Nov 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Washing Machines Logo
16 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
