Question about Select Jazzy Used Electric Wheelchair
Jazzy 1113acs Error code 54
I'm working on the 2004 Jeep Grand Cherokee 4.7 showing error codes
lashes 52 and 54 ,you do mean flashes ? What flashes ? Check engine light doesn't flash codes .
Apr 24, 2017 | Jeep Cars & Trucks
Error log code 2000
Call pride, 1-800-800-8586
May 16, 2016 | Pride Jazzy Select 6
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
LED"s flash an error 8
hi,
Joystick code 8 == Controller error
Three red LEDs
Four yellow LEDs
One green LED.
Please confirm this, if you're UK based , i can repair these units...
regards
Rob
www.gewizrepairs.co.uk
Jul 10, 2015 | Pride Jazzy 600 JAZZY 600
What does the error codes 0603 and 0503 mean?
hi, please look at the following manual
file:///C:/Users/Robin/Downloads/INFINFB2468_Jazzy_614_614HD_Troubleshooting.pdf
Regards
Rob
Jun 04, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Error code 54
http://www.pc-library.com/errors/error-code/54-0x36/
Mar 08, 2013 | Biostar Computers & Internet
I have an error code of three on my jazzy 614hd power chair
hi, Please take a look at the following link:
http://www.pridemobility.com/resourcecenter/Downloads/Basic_Troubleshooting_Guides/basic_troubleshooting_guides.asp
Regards
Feb 17, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Hope this helps
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy 1420 not 1170
sounds like the wiring from the motor to the controler is not making good connection, try unpluging motor wiring from controller box. Use a plastic safe elec. contact cleaner and lube spray on connections. water in the joystick can also cause this.
Jan 05, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
Select Jazzy Used Electric Wheelchair Logo
22 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
