Question about Yaesu Ft-902dm Ft-901dm Pb-1709a Pll Unit
Is the Pb-1709 and the Pb1709a the same
Ft-901dm I need a replacement pll unit. Is the Pb-1709 and the Pb1709a the same
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
It appears that there is one transistor difference in the two models.
Posted on Dec 30, 2014
  • langhi Dec 30, 2014
Push on ..... PLL unlock
Would you elaborate on your question?
Jul 06, 2014 | Yaesu FT-920 Transceiver
Flashing display ft 840
Radio needs service, flashing display means the PLL is out of lock
Mar 20, 2014 | Yaesu FT-840 Owners Manual
H/p input on display clicks on and off
Need to either unplug the cable to the headphone jack board (if you don't want to use the headphone jack), or have the jack replaced. This is a common problem with these models. The is a short in the headphone jack that makes the unit intermittently think there is a set of headphones plugged in even when there isn't.
Aug 14, 2013 | Denon AVR-1709 Receiver
DENON 1709: The sound is OK when STEREO is setting. Using 5.1 STEREO or MUSIC or CINEMA setting all the speakers are working, except Front Right. I check the volume for each speaker and set it up to the...
The Stereo setting does not use any digital processing and likely avoids the decoding board completely. From your description, either the signal is not being decoded properly or the right channel signal path is being interrupted somewhere. Without taking measurements inside the unit, I cannot tell for sure where the problem lies. Careful examination of the processing board is required here. Take the unit to a repair shop for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair.
Dan
May 29, 2011 | Denon AVR-1709 Receiver
Pll broken
If the PLL is dead, it's almost not worth saving. Even if you get a replacement PLL and change it, the radio will not work right without an alignment. To align the radio you will need the factory alignment guide, watt meter, volt meter and an oscilloscope and a basic knowledge of electronics.
Oct 20, 2010 | Uniden BCD396T 6000-Channels Handheld CB...
Connect denon 1709 to my tv
I will assume that your TV is an HDTV capable unit. Since I also would assume that the Denon AV1709 is properly setup in your listening room/Home Theater. You will need to purchase one HDMI cable from the Denon to the TV input. This cable must be long enough to go from the Denon to the TV with length to spare. The more money spent on a better quality HDMI cable will pay dividends on how much better the screen will appear. On the back of the Denon is an HDMI output labeled "Monitor Out" that the new cable will go into, and the other end of the cable will go into the TV input labeled HDMI. On the remote I would search for a button labeled "Input" or "Source" and on the screen I would look for the input that would reflect the same input you put the HDMI cable into in the TV. If your TV doesn't have HDMI inputs see if it does have "Component input" on the back The information will be similar but will reflect the different Input and Outputs you may need to use. The cables will be more complicated but they are color coded just for you. Red goes to Red, Blue goes to Blue, Green Goes to Green. Enjoy Re-Post if you need further information.
Sep 16, 2009 | Denon AVR-1709 Receiver
I want to know how to convert my superstar121
3 Bands (LOW - MID - HIGH) 25.515 - 27.855 MHz.
Export Frequency Conversion
1. Remove the top cover from the unit and locate the PLL chip (MC145106P). Unsolder the short jumper wire running from the +8.2vdc source to pin 9 of the PLL chip. 2. 2. Resolder the three pins of the PLL chip, Pins 10, 11, and 12, being carefull not to short them together. Note: The Super Star 140 Microphone wiring is the same as all Midland Radios.
Mar 12, 2009 | Superstar SS-121 120-Channels Base CB...
IC-R8500--Display is flashing continuously--no receive
First check the tape cables from Conv Unit and Rf unit to main unit.
Second find if the PLL ICs lock (MC145190) check voltage at pin 2 (LO) ~4,5Vdc in PLL Unit.
Third find If the (PQ30RV31) voltage ADJ in main works.
Nov 01, 2007 | Icom IC-R8500 Base Scanner
Yaesu Ft-902dm Ft-901dm Pb-1709a Pll Unit Logo
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
