Question about KitchenAid Kitchen Ranges
Kitchenaid error f3e1 main sensor shorted
Just had this message pop up out of nowhere. What can I do to fix it?
Whirlpool oven Super Capacity 465 error F3E1
The F3 E1 error indicates a problem with the oven temperature sensor or a short in the oven temperature circuit. To trouble-shoot this error, unplug the oven. Check the wiring harness for damage and then reconnect it, if it is undamaged. Next check the resistance across the oven temperature sensor. The resistance should be 1080 Ohms at room temperature. Replace the sensor of the resistance is not correct. Otherwise replace the main control board.
Please add a comment with the model of your oven if you want me to look up the parts list or diagram for your appliance.
I hope this helps.
Aug 05, 2017 | Whirlpool Ovens
Whirlpool washer F3 E1
F3E1 Error - Pressure switch/ sensor fault.
  • Your washer cannot detect the water level. Check the pressure sensing hose for kinks or blockage or the pressure sensor itself.
  • I won't leave you without a clue. Follow the link below and it will explain more than I can write here.
  • http://applianceassistant.com/Washer-Repair/Duet/Duet-Washer-Error-Codes
  • Jan 02, 2017 | Whirlpool Washing Machines
    Kemc377. Why is it showing error code?
    F1 DOOR SWITCH
    F2 KEYPAD
    F3 TEMPERATURE SENSOR
    F4 MEAT PROBE SHORTED
    F8 SELF CLEAN LATCH PROBLEM
    All other errors, replace the main oven control
    Aug 23, 2015 | KitchenAid Ovens
    Whirlpool range rf386pxd e1 f3
    The F3E1 error indicates that the oven temperature sensor is shorted. The part most be replaced.
    The sensor is part 8053344 for most models. See http://parts.sears.com/partsdirect/part-number/3148440/0022/664?keySuffixId=NA&brandId=1198&modelNumber=RF386PXDB0&productCategoryId=0124111&pathTaken=partSearch&pathRender=modelComponent&componentPartName=Unit&documentCompId=O2022127&diagramPageId=00004&blt=&prst=&shdMod= .
    There are several models of the Whirlpool range in the RF386PXD style. The parts lists can be found on many sites, including http://parts.sears.com/partsdirect/part-model/RF386PXD?prst=0&shdMod=RF386PXD . You may want to check the parts list for your exact model before ordering.
    I hope this helps.
    Nov 29, 2012 | Kitchen Ranges
    Error code f2
    see this causes and fix it. Read your instr.manual for codes. God bless you
    F2---Touch Panel Failure Check connections, Replace Control
    F2--Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking. Check oven temperature sensor for continuity. Replace if zero or infinite ohms.
    Sep 30, 2012 | KitchenAid Microwave Ovens
    Engine Light is on steady. Disconnected the battery and it re connected but is still on solid.
    if a sensor is sending an error message which turns the light on, why would disconnecting the battery fix the error message? it will continue to detect the error until it is fixed. that is done by taking it to a trained person who attaches a diagnostic analyzer, gets the codes to figure out what is wrong and fixes it.
    the other way is to ignore it and let it fail completely when you are in the middle of nowhere, at night in bad weather and your cell phone battery is dead.
    Feb 12, 2011 | 2005 GMC Yukon Xl Denali
    Kitchenaid DF Range F04 error code
    I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
    Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
    F2 F3 and now F4 error message
    F2 is oven temp too high
    F3 is open sensor OR thermal fuse
    F4 is shorted sensor
    1.Check the thermal fuse
    2. Check that the sensor is installed properly.
    3. install new sensor.
    Apr 27, 2009 | KitchenAid KESC307 Electric Kitchen Range
    F2e0 error on stove
    Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
    --> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
    Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
    Open Questions:
    Kitchen Ranges Logo
    20 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Dan Webster
    Dan Webster
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
