Question about Samsung UN60D6000 60 Inch 1080p Smart TV LED LCD HDTV
Samsung logo in left upper screen
Only goes away with mute or other channel logo
    Habit-Forming:
  • 84 Answers
Search thru the setups in the menu for a store/home setting. Sounds like it may be set to a demo mode that would be used in a store.
Posted on Mar 22, 2014
The logo signage is stuck on the top left part of the screen how do i remove it?
Hi Carly, just get your fingernail under the top corner of the label and lift it up so that you can hold it between tip of thumb and forefinger then peel it away to the opposite side from where you are holding it. Do not use anything that may scratch the screen or any liquid or other product. Please tick my "helpful" box if this solves the problem. Good luck Carly.
Nov 27, 2015 | Televison & Video
Xo vision xtab factory reset
I had been trying to locate how to access the recovery options for the XO Vision XTAB tablet as well. Mine would show the XO Vision logo on start-up and then show a cursor in the upper left corner for a few seconds and then showed "ANDROID" a little further down and to the right of the upper left hand corner with a flashing cursor right behind it.
I was finally able to get into the recovery options press HOME, VOLUME UP, & POWER at the same time and hold for about 6 seconds or so. You need to let go before the XO Vision logo goes away. Wait until the logo goes away and a cursor should display in the upper left hand corner and then you'll get to the recovery / update options screen.
Use the VOLUME UP / DOWN keys to navigate the menu and then you'll press MENU to select the option. After that let it run through its processes until it completes. My attempt was unsuccessful at a factory reset and I'm still not sure how to fix it, however, you may have better luck.
Apr 08, 2013 | XO Vision Xtab Android Ebook Reader
Samsung laptop black screen
video chip problem,contect service center
Mar 10, 2013 | Computers & Internet
Can't get rid of LED TV logo on Samsung TV
Apparently it's on demo-mode so you have to go to 1. Set up 2. Plug and play 3. Then change to home instead of demo
Jan 27, 2012 | Samsung 32 UN32D4000 LCD TV
Dell Inspiron mini 10. The system will not boot up, after the Dell logo screen and blue bar goes away, the screen is blank and the curser is flashing in the upper left corner of the screen. F11 isn't...
That cursor indicated that the BIOS can't find an Windows installed on the hdd. Since even the recovery partition appears to be inaccessible the only thing left is to reinstall it using the recovery cd that should have come with it when you bought it If you don't have it you can order it from Dell.
Sep 01, 2011 | Dell Inspiron Mini 1012 Netbook...
Where is the mute button on the Casio gzone boulder phone?
Once you've dialed your phone number and are connected... press "CLR" until the numbers are erased from the screen... Then you'll notice that the "mute" appears on the lower left of the screen. Just press the Upper Left Key "-" and your muted !
Aug 31, 2010 | Casio G''zOne Type S Cellular Phone
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
Mute and C on the screen
The TV is in factory or demo mode - turn tv off and unplug it from wall outlet for 30 seconds - turn tv back on after 30 seconds and see if problem goes away. If not, press the (volume -) and (channel -) buttons repeatedly for about 10 seconds to see if "C" will go away. If this fails call 1-888-PHILIPS for further assistance (they do Magnavox also).
May 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
Dec 12, 2007 | Televison & Video
Samsung UN60D6000 60 Inch 1080p Smart TV LED LCD HDTV Logo
69 people viewed this question
Jerry Greenberg
Jerry Greenberg
