Question about SkyGolf GPS Skygolf Cgt Gimme Digital Gps Skycaddie
Skycaddie is frozen
Screen is frozen
I can't get my skycaddie to move.It's like it's frozen
Hi Dorothy,
The first thing you should do is remove the battery. After replacing the battery make sure it is completely charged. After that, turn your skycaddie back on and it should work normally. Make sure that you are outside with an unobscured view of the sky. When you secure access to satellite your GPS should record your movements larger than 50 yards or less. I would use my phone to verify my exact location.
Cheers,
Dr. Bob
Jun 11, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
Reads, Application not found!Skygolf.com/SGXrecover
i have tried several things but no response, screen is still reading application not found skygolf.com/sgxrecover
Dec 31, 2012 | SkyGolf SkyCaddie SGX GPS Receiver
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
Screen frozen with the letter X on it
rest by holding down toggle and on/off button for 8 sec
May 07, 2011 | SkyGolf SkyCaddie SGX GPS Receiver
My skycaddie is frozen [happened when i tried to sync] and will not turn off. tried the soft reset but to no avail......what's next?
The only thing you can do is dis-connect the rechargeable battery for at least 60 seconds, this should clear the microprocessor.
Apr 13, 2011 | SkyGolf SkyCaddie SGX GPS Receiver
How do I renew a subscibtuion to Sky caddie?
You need the CaddieSync software installed on a PC.
  • If you have not already done so, you can download the software HERE.
  • Connect your SkyCaddy to the PC.
  • You can renew your membership on the Account Overview page in CaddieSync.
    If your membership has expired:
  • Turn on your SkyCaddie and connect it to your computer.
  • Launch CaddieSync. If No SkyCaddie Synced appears in the lower navigation bar, click the Sync button.
    To ensure your courses are updated and downloaded to your SkyCaddie, click the COURSES tab at the top of the CaddieSync screen and select Favorites. You can manage your courses on this page or download courses to update your SkyCaddie.
  • Click the ACCOUNT tab in the upper navigation bar.
  • Login with your username and password. If you do not recall your password, click Forgot your username or password?.
  • On the Account Overview page, click link the Renew link under Actions at the lower right of the CaddieSync window.
If your membership has not expired, you can use the same procedure to renew.
When you renew your membership within 90 days of expiration, you retain your current expiration date as your activation anniversary. You do not risk losing your membership by renewing early.
Dec 27, 2010 | SkyCaddie SG2.5 GPS Receiver
SkyGolf GPS Skygolf Cgt Gimme Digital Gps Skycaddie Logo
91 people viewed this question
Top SkyGolf GPS Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a SkyGolf GPS Optic Expert? Answer questions, earn points and help others
