Question about John Deere 22HP VTwin 48" Riding Mower
Oil change What kind of oil and how much does it take to refill...
I have a 1996 mustang with a 2005 f-150 engine in it. It has sat in a garage for 7 months without being started,what should i do before starting it?
hi,im elroy, u should change the oil and oil filter,drain old oil and refill with new oil, dont forget to change the oil filter before you refill with new oil.change all spark plugs
Feb 01, 2013 | 2005 Ford F-150
Where is oil plug to change oil, how much and what kind. It is a 6.25 hp 22 inch self propelled Murray Select Quantum.
They do not have a drain plug. You need to remove the dipstick and tip the mower dipstick side down while putting a container under it. After it has drained right mower and refill to full mark on dipstick with sae 30 engine oil. It will take approximately 600 mls. Regards Phil
Apr 17, 2011 | Garden
What is the oil capacity of a 1993 Nissan SEV6 D21 pick up? thank you
Refill
oil amount with oil filter change: 4.25 quarts Refill oil amount without oil
filter change: 3.875, depending on engine size as well, this could be up 5ltrs..
Dec 02, 2010 | 1993 Nissan Pickup
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2001 Dodge Durango
Vehicle deferential oil change. does it mean transmission oil? or this is something else?
Differential oil change is rear axle oil
Drain and refill
Oil grade SAE 90
Refill 0.9 litres
Mar 28, 2010 | 2003 Toyota RAV4
What oil is inside a 1/3 HP 1725 RPM effluent pump
You can refill it with capella oil. This is the same as the oil used in refrigerator compressors, and be acquired
from stores specializing in refrigeration and airconditioning. Send us an e-mail for further assistance.
Jun 29, 2009 | Submersible Systems Submersible Sump...
Powersteering
typically no one changes power steering fluid but if you insist you will need an evacuation pump or some kind of suction pump and just **** the reservoir dry and then refill with new oil
Apr 21, 2009 | 1995 Mazda 626
Oil and break in
3.6L of fully synthetic oil with a filter change. Genuine Suzuki filter  recommended. No running in, you can thrash it like suzuki intended.
Dec 12, 2008 | 2007 Suzuki GSX-R 1000
John Deere 22HP VTwin 48" Riding Mower Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
