Question about Dell 5330dn Laser Printer
Dell 5330 paper jam error
Paper jam half way
JSPCEXPRESS
  • 178 Answers
SOURCE: Dell 3000cn Laser Printer Problem--Paper Jam
Hello how are you Take the tray out on the bottom and see if there is a piece of something in there. Mine does this sometimes. Also on the back there is a drawer open this up and check. Have you taken out the toner yet. Do this and once you check every area as described turn power off to it and leave off for min. Then power back on and push cancel button about 5 times let me know if this works for you. It does for me
Posted on Feb 13, 2008
SOURCE: Paper Jam error
If it works like the 1700n (I think it does), if you press Continue twice it should light up different lights as a secondary error code. It should tell you close to where it thinks the paper jam is. Check the sensors there, clean them, whatever. If you have a spare printer, or another one, you may try switching out the sensor (takes some tearing apart of the printer) and see if that fixes it.
Posted on Jul 17, 2008
  • 5 Answers
SOURCE: Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Posted on Jan 09, 2009
SOURCE: paper goes half way through and then stops and registers paper jam!
http://www.fastprinters.com/ProductDetails.asp?product_id=LEX-56P1826
Exit sensor is broken , look for the same part for a Lexmark E330 if the URL dies.
Posted on Mar 26, 2009
devdeep545
  • 137 Answers
SOURCE: Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Posted on Aug 09, 2009
Xerox WC 5330 error Code 010 338
I think it is a toner or maybe paper issue, as a first step I would remove and re install both
Jul 13, 2016 | Xerox WorkCentre 5330/P Printer
How do I get the paper jam error message to turn off after fixing jam on Dell C2660 printer
Turn the power off and let it sit for a few minutes. While it is off, open all the paper path access areas and check for any pieces of paper or buildups which may affect a sensor.
Close it back up and turn it on.
Here is a link to the manual, which has two good areas covering paper jam troubleshooting and resolution (around pg 300). http://www.manualslib.com/download/577729/Dell-C2660dn.html
Mar 03, 2015 | Dell Color Printer - C2660dn
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
Jan 03, 2009 | Dell 3100cn Laser Printer
Paper wont feed then says paper jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect)
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Oct 30, 2007 | Dell W5300N Laser Printer
Dell 5330dn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
