Question about Mtd 22" Yard Machine Push Mower
Push mower runs for 3 seconds and dies brand new mower used it 2x
Need help
  • 77 Answers
If the carb mounts directly on top of the tank chances are the diaphram gasket between the carb ant tank has swelled and needs replaced
Posted on Aug 09, 2009
Have a 6hp craftsman mower starts and runs for 30 sec dies have replacer carb with running mower carb replaced plug replaced coil flywheel key fuel tank sounds like it is seizing up slows down for a
you have bad valves seats probably broken loose do to overheating replace short block or by new motor short block cost to much 300.00 new motor 225.00 to 245.00
Sep 07, 2014 | Garden
MTD Briggs and Straton 22" Mower Wont Start Brand
You probably have dirt in the carburetor. Or, you may have water in the fuel. As long as you have spark, then there is nothing else that it could be. Unless you have taken it apart already; have you done this?
Jim
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
Brand new 550! push red pump button 3-4 times... pull handle..mower starts up then dies. Will not continue to run..
Sounds like wet fuel! The priming puts enough gas in to start it but the running circuit does not.
Check your gas can for a layer of water on the bottom of it. If it has a lot of water in it you should dispose of this fuel at a gas station that collects used oil and gas. Drain the mower and take that gas away too.
Put in fresh gas from a known clean and dry source.
Let me know what you find ok?
Good luck and be careful!
Jun 29, 2010 | Craftsman 550 Torque 22 in Deck 2n1 Side...
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
511 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
