Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
I JUST GOT A JANDY AQUALINK RS ONETOUCH CONTROL SYSTEM INSTALLED BY A PROFESSIONAL INSTALLER AND HE SHOWED ME HOW TO USE THE CONTROLLER. IT WAS WORKING PERFECTLY BUT AFTER A THUNDERSTORM THAT NIGHT ALL I CAN SEE IS A LIGHTED GRAY SCREEN BUT NO TEXT AND THE HEATER LED IS FLASHING GREEN WHEN IT SHOULD BE RED WHEN THE HEATER IS RUNNING. REGARDLESS OF WHAT BUTTONS I PUSHED NOTHING HAPPENS. I CAN STILL GO TO THE POWER CENTER AND TURN THE PUMP OR HEATER OR SPA OR AIR BLOWER ON MANUALLY AND THEN IT WORKS. WHAT MUST I DO TO GET THE GRAY SCREEN TO SHOW THE TEXT OR COULD THE THUNDERSTORM DAMAGED IT?
  • dr104213 Jun 18, 2009
    THE TECHNICIAN CAME OUT TODAY AND ALL HE DID WAS TO UNPLUGGED IT AND WAITED FOR ABOUT A MINUTE AND REPLUGGED IT AND IT WORKED! UNFORTUNATELY, WHEN I GOT HOME FROM WORK (ABOUT SIX HOURS AFTER THEY WERE HERE) AFTER I GOT HOME THE PUMP WAS WORKING BUT THERE WAS NO TEXT SHOWING ON THE GRAY SCREEN, ONLY JUST THE GRAY LIGHT ON THE SCREEN. I EVEN TUNED OFF THE POWER AT THE HOUSE CIRCUIT BREAKER BOX FOR ABOUT FIVE MINUTES THEN TURNED IT BACK ON BUT STILL NO TEXT. WHILE THE POWER WAS OFF I NOTICED THE SCREEN LIGHT WAS OFF, TOO./ WHAT SHOULD I DO?
  • 1,555 Answers
It seems that your display ic's got surge due to storm. When technician came and removed it from power He simply reset your control system and whatever surge was there in the buffer was gone. Once you kept it again with the power it again started accumulating surge from the power supply which if you will reset will once more go but it will reoccur due to faulty ic. It is recommended if you need permanent solution to send the faulty unit to the company for IC replacement alongwith your comments as it is accumulating surge and display cuts off after a certain period of time. Else if you wish to reset it everytime yourself then below is the link to the pdf manual of your control system in which detailed resetting instructions are provided you can use this for resetting your control system and get your display back.
www.southshoregunitepools.com/resources/manuals/jandy_installation.pdf
Posted on Jun 18, 2009
  • 3,230 Answers
Yes The Thunderstorm damage your jandy.
You need to check all the control bottons and ic's by using a multi-meter.
Thanks
Posted on Jun 14, 2009
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
Solar has disappeared from my Jandy Aqualink RS control
go into system setup assign the solar to a aux it should work
Apr 10, 2014 | Jandy Aqualink Rs4 One Touch Control...
Indoor panel is a code 7202 rev HH showing?
need more info is it a wired controller if so make sure 4 pin red plug is plugged into bezel board sometimes they unplug for winterization if plugged in make sure where it goes into house or into RS system that the wire isnot cut or nicked sounds like it isnt seeing controller if all ok shut system down and reboot
Apr 07, 2014 | Jandy AquaLink RS OneTouch RS16 Pool or...
Code 7202 rev HH ?
need more info is this a wired controller if so check to see if 4 pin red connector is connected also see if maybe a landscaper cut the wire by the aqualink or where it goes into the house
I have a Jandy Aqualink RS OneTouch Wired Control Panel. The units light is on but there is no LED display. The unit continues to operate and turn the pool pump on and off at the scheduled times,...
It sounds like the unit itself may be out. The acid test would to be to get hold of a new one and switch them out. See if you can find a local pool company to work on that for you.
Dec 26, 2012 | Jandy AquaLink RS OneTouch Wired White...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
91 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
