Question about Denon Remote Control RC920
Have a denon re-920...will it control my hdtv? how do I sync these?
How can i control my tv also
Have denon al 24 how do you adjust speech syncing with the tv
sound syncing comes from the transmitting station .there is no adjusting .
Jun 22, 2016 | Denon Audio Players & Recorders
Will a RC-920 work in place of a RC-1002?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 16, 2014 | Denon Televison & Video
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
Sound out sync
Is the source of the picture from the tv or an external source
Jan 26, 2014 | Denon AVR-2307Ci Receiver
Lip sync
should be in set up menu in denon receiver
Dec 31, 2012 | Denon RC-1149
My Denon AVR 1905 is hooked up with surround sound to a new LED Samsung 6200 series. The picture is fine / the sound is fine but the lip sych is not. Is there any way to fix this??.I have had a technician...
You need to see if the TV's sound, not the receiver is out of sync also. Turn up the sound on the tv and turn down on receiver. If it syncs correctly, your receiver isn't fast enough to process both correctly. You will have to upgrade your receiver to one that supports HDMI 1.4. Samsung sells one that works great, model # <span class="Apple-style-span" style="font-family: 'Lucida Grande'; font-size: 12px; ">HW-C500. </span>
Aug 05, 2010 | Denon AVR-1905 Receiver
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Audio Out from Samsung LE40F86BD
check your samsung owners manual for audio settings to see if this model has a audio time delay setting .
Feb 26, 2008 | Hitachi 51F510 51" Rear Projection...
Using Windows Media Player 11 or Real Player 10.5 to Transfer Music
I have one of these too and it cannot be used with media player 11 as there are no updated drivers. Use media player 10 and you should have no problems.
Jun 01, 2007 | Samsung Napster YH-920 MP3 Player
Denon Remote Control RC920 Logo
26 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
