Question about Samsung Brightside
Battery shows phone is charging
Sony xperia miro st.23i is showing charges but not charging I have try so many different charger but still not charging he keeping showing charging but if you removing the charger showing low battery and I...
These are my suggestions.
Possible issues.
The USB port on the phone is faulty and not making proper contact.
The battery charger you are using is not of sufficient current to charge the battery fast enough.
The charger/regulator circuit in the phone may be faulty. unfortunately it is not user serviceable.Have the phone repaired by a qualified technician.
Possible solutions
You may be able to purchase an external battery charger and use that then insert the battery in the phone.
Mar 26, 2015 | Sony Cell Phones
My LG RD 6100 is showing charging but it is not actually charging.After removing charger it is showing that recharge the battery
It is best to get the charger checked with another phone as to confirm the case. In some cases the low regulation within the phone can efffect the charging circuit.
Also cross check the battery as if the battery is weak or had been not charged initially properly then it seems a suspect.
Dec 29, 2011 | Cell Phones
Hi. I have a prblm in Samsung s5620 monte. The prblm is that my phone showing the charge but it not getting charge. What should i do?
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Samsung Cell Phones
Battery
change the phone memory
Apr 02, 2010 | LG Vu CU920 Cellular Phone
I have a cordless KX-T7885 and can't get the battery to charge. i replaced the batteries and both phones but they both will not work. They sat for two years and I have just recently tried to use them. They...
If you have a multi-tester, check the voltage on the battery packs. The voltage should be equal to or greater than the voltage listed on the battery pack. If the voltage on the packs is too low, either the battery packs are defective or the charging systems of the phones are not operating properly. If the phones are not charging properly, it is likely not cost effective to try to get it repaired.
Oct 10, 2009 | Panasonic KX-T7885 Cordless Phone
My k550i shows, 'charging alien battery' some times i'm connecting to plug, some times it shows 'optimized charging'. wats d difference between these 2 messages.
The battery you are using is not of good quality.Alien battery actually is categorized as the lowest quality of compatible batteries, Optimized Charging refers to the advanced charging circuit in SE phones that prevents damage and ensures the battery is properly charged.
Jul 16, 2009 | Sony Ericsson K550i Cellular Phone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
NTO ABLE TO CHARGE BATTERY
Try charging the battery for a long time.
Feb 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
K1 Problem Charging Battery
sounds like the battery to me. there is a chance it is the phone. Check on your warranty and see about a battery replacement first. Its much more likely.
Jan 13, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung Brightside Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
