Question about Garden
Polaris trouble codes 746
Trouble code 746
  • 231 Answers
SOURCE: obd1 trouble code
25) is mixture control continuously lean
42) is VSS circuit - vehicle speed sensor
43) is starter signal circuit
Good luck and I hope this answers your question. And remember to rate all the solutions that you get, thanx.
Posted on Oct 31, 2008
localwonder
  • 6784 Answers
SOURCE: trouble code p2000
P2000 NOx Trap Efficiency Below Threshold (Bank 1)
This code usually indicates a faulty oxygen sensor(s). However, in some instances it can also be used for a faulty catalytic converter as well, since the O2 sensors are located on the exhaust system along with the cat. converter(s). You should check your O2 sensors before replacing the catalytic converter. Here is a guide on checking these sensors.
All engines run on a optimum fuel to air mixture called "stokiometric" which means chemically balanced. This balanced fuel to air ratio is 14.7 to 1, 14.7 parts air to 1 part fuel. The oxygen sensor is created using the active chemical such as zirconium, electrochemical (also known as Galvanic), infrared, ultrasonic and very recently laser. When a lean mixture code is detected by you or a technician the first tendency is to replace the oxygen sensor. The best way to check the operation of the sensor is to run a simple test. No matter if your engines oxygen sensor has one wire or four there is only one sensing wire that feedbacks information to the PCM. To find this wire you will need a car repair manual. If a trouble code is present that pertains to a oxygen heater sensor failure, replace the sensor to repair the problem. A oxygen sensor must be warm before it will operate properly.
Warning: If a malfunction exists with related components such as an engine misfire or engine vacuum leak do not perform this test. The oxygen sensor to designed to operate within a particular range, if this range is exceeded the sensor will give the appearance that it has failed.
SENSOR TEST PROCEDURE---
  • Step 1 - Once the oxygen sensor sensing wire has been located connect a volt meter to the feedback wire and ground. Select the millivolt operation on the meter.
  • Step 2 - Next, start and run the engine at idle until warm (about 15 minutes). Observe the voltmeter, it should bounce slightly at whatever voltage the sensor is centered at (about 150 millivolts).
  • Step 3 - Continue to observe the meter and have a helper rap the throttle. The meter should drop for a split second as the mixture leans out in the first milliseconds of the throttle bore being opened. Then quickly rise for a spit second as the throttle closes and the mixture richens. The volt meter should stabilize at the original operating voltage when the engine returns to idle.
Remember, if the sensor fails this test, replace it but if it passes, replace the Catalytic converter...
Please rate and have a great day:)
Posted on Apr 30, 2009
bschilz
  • 2049 Answers
SOURCE: 99blazer s10 trouble codes p171/p174
P0171 - System Too Lean (Bank 1)
Basically this means that an oxygen sensor in bank 1 detected a lean condition (too much oxygen in the exhaust). On V6/V8/V10 engines, Bank 1 is the side of the engine that has cylinder #1.
A code P0171 may mean that one or more of the following has happened:
  • The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor.
Possible solutions include:
  • In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
  • Inspect all vacuum and PCV hoses, replace if necessary
  • Check for a dirty fuel filter and proper fuel pressure
P0174 is identical to P0171, except it indicates the problem exists on Bank 2 as well.
Posted on Nov 22, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Posted on Dec 12, 2009
  • 39 Answers
SOURCE: 2003 saturn vue trouble code p1599
P1599 IS A STALLING ISSUE COULD BE BAD GAS / BAD FUELPUMP DIRTY FUEL FILTER
DISCONNECT BATTERY AND SEE IF THE LIGHT COMES ON AGAIN
U2107 HAS SOMETHING TO DO WITH THE COMPUTER LOOSING POWER AT THE BODY MOUNTS CHECK CABLES AND GROUND STRAP
Posted on Mar 02, 2010
What does 110 code on a 2010 polaris 800 mean plse
There is a trouble shooting procedure for the ECT, Temp sensor. There are different resistance reading for different temps.
http://www.polaris.com/en-us/atv-ranger-rzr/owners-manual
Jun 01, 2017 | ATVs
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
How to fix error code 746 5?
turf mode driver they had problems with them it my be a recall check your local dealer
Sep 12, 2015 | Polaris 2012 Ranger XP 800
Ecu is not communicating with the EPS. Check wires
Aug 27, 2014 | Polaris 2013 Ranger Crew 800 EPS Blue Fire...
Polaris trouble codes 168 what would cause this
Billy call the dealer for code explanation and get a manual.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Aug 18, 2014 | Polaris 2012 Ranger RZR 570
Polaris trouble codes 168 what is this problem
168 is a High Voltage. If it continues you may be having a voltage regulator about to or already gone bad.
The Machine is new, do you have a warranty? Has the machine been sitting for a while? If so, a professional carb/fuel system cleaning and a new spark plug should take care of it.
I WOULD take it o the dealer and find out what the code means!!
Jul 25, 2014 | Polaris 2014 Ranger 570 EFI
I disconnected my TV when we were having work done in the house. At the time I had no trouble getting Sky. A new connection to the dish has been installed but I cannot get onto Sky. I have checked the...
Hello
To synchronise with sky you have to resynchronise it, as you have disconencted it and reconencted with new one. The sky remote codes for Toshiba to check with are:
28W93B 2563DB
Toshiba
156T9B 175T9B 213T4B 2151TB 2197DB 2512DB 2535DB 2539DB 2550TB 2563DB 256T9B 28Z27B2 2812DB 2857DB 2835DB 2873DB 2877DB 28W93B 2500TB 3357DB 573DB 2879DB T1510T8 25001TB7 32DB 32M8DB 2855DB CT9689 2939DB 40PW03B MV40PWA 32M9DB3 2893DB 32317B 2573DB 337BB 2552D 36/21P 28207B 2173DB 285T8B 2173DB 28W8DBA 28N03B 2505 238DB 439J936 3377DB 2181TB 82Z27B 28W23B 32ZP18P 42PW33P 32NW2DB 28ZH37B 32W8DB 32ZP38B 32NW7DB 32WIS 28N33B VTV1400 2987DB
536
Toshiba
2101TB 213T4B 2573DB 32ZP38
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
Toshiba
14T01B, 21TO1B, CT815, CT81500082B, CT824, CT832
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
2987DB 3339DB 2877DB 322D09B 2173D6 14N21B2 14N21B2
063
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
Oct 05, 2011 | Toshiba 32WLT58 32 in. LCD Television
Cant disable simlock code on a samsung e250.
Hi Use the following code
#7465625*746*Code# ( Disables SIM lock)*7465625*746*Code# ( Enables SIM lock)
Use this code on your phone to disable/enable SIM Lock on E250
Jun 21, 2011 | Computers & Internet
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
