Question about Danby DFF282WDB 10.0 cu. ft. Freestanding Top-Freezer Refrigerator with 2 Adjustable Glass Shelves, See-Through Vegetable Crisper, Frost-Free, Mechanical Thermostat and Interior Light: White
Parts Diagram I would like to purchase condiment bars for this model. DFF282WDB
How can I find a wirning diagram for a ice maker that has guit making ice but the pump will run?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Your Ice machine does not have a wiring diagram. I have repaired many of these.
1.) Are you getting water? If not it is your pump.
2.) Reach in and feel the cold plate. Is it cold? If not you have a refrigerant leak.
3.) The problem may also be within your main control board.
Unless you have a current service contract these units are considered throw-always. It will cost you twice as much, if not more, to repair it than what you purchased it for, assuming you call a service company.
Go into the following website. Plug in the first 5 numbers on your model number and a list of model numbers will appear. Your model number is incorrect.
Select the model number then click on parts and you will get diagrams of your icemaker. Water Filters Lawn Garden Appliance Parts
Mar 21, 2015 | KitchenAid 18" Ice Maker - Black
Danby DFF282WDB stopped cooling - light comes on - any troubleshooting we can do?
Hello;
You are locked into the defrost mode. This is when every 8-10 hours your unit will shut down for 20-30 minutes and your defrost heater comes on and defrost your freezer cooling (Evaporator) Coil. During this cycle everything shuts down except for the light.
Your controls are usually located on the top of your fresh food section. On the bottom of your controls, near the front, left hand side there is a round hole. This is where your defrost timer is located.
With a large flat head screw driver turn clockwise. You will hear a clicking sound. Turn slowly one click a time until your unit turns on. This unit will have to be replaced. Until it is replace manually turn it off every 10 hours for 20 minutes.
Note the round stub on the left.
Feb 23, 2015 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
My refrigerator is warm but the light inside turns on and i have it set to cold, it just stopped working today
Have you unplugged the fridge sir? checked for any electrical disconnections? dust clogging your tubules in the back? Enough space between the wall and fridge in the back? sometimes these will do it. Your fridge needs air to oxygenate the tubules so that it does not overheat and not work.
Jan 07, 2014 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
I have an Imperial heavy duty freezer, model # UL2494ECW5. My door seal is ripped pretty good. Where could I purchase another rubber seal for that model?
The part number for that gasket is 216522312 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Sep 09, 2011 | Freezers
I need to replace the thermostat on my very old Kenmore Coldspot Upright Freezer, model 106628420. I have no owners manual and there is not one to be found. I would like any help possible. Thank you so...
Not that this diagram is a lot of help, but I did find this on a Sears website:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Freezer-Parts/Model-106628420/0582/0142000?sid=PDVertical
Nov 10, 2010 | Kenmore Freezers
I have a Frigidaire freezer that I bought in 1994. It's a 17 cubic foot upright, model #FFU17M6AW. I need to replace one of the brackets that hold the bars for the door shelving in place. It's a plastic...
you can most likely order this part from marcone appliance parts or allbrands appliance parts they both have websites and both mail to your door marcone will most likely be able to steer you in the right direction hope this helps
Jul 13, 2010 | Frigidaire Freezers
Freezer quite working after an electrical surge in area...
tell her to change the rely on the compressor if there is an appliance parts store tell her to get a three in one reley and follow the instructions that come with it
May 25, 2008 | Freezers
Danby DFF282WDB 10.0 cu. ft. Freestanding Top-Freezer Refrigerator with 2 Adjustable Glass Shelves, See-Through Vegetable Crisper, Frost-Free, Mechanical Thermostat and Interior Light: White Logo
76 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Michael Van Der...
Michael Van Der...
Are you a Danby Freezer Expert? Answer questions, earn points and help others
