Question about Xerox WorkCentre XD125F All-In-One Laser Printer
L6 message on top
L 6 message flashing
What does L6 mean on my Garrison carbon monoxide detector, it beeps then that message flashes, and then it beeps again . It is a plug in and does not need a battery.
L6" display & chirping sound, indicates you need to change the 9 volt battery in the detector.
Please rate me as HELPFUL.
Jan 26, 2017 | Home Security
Tip
What is the firing order for 2004 BMW 330 (E46) 2.5 liter L6 DOHC (M54)?
the firing order for 2004 BMW 330 (E46) 2.5 liter L6 DOHC (M54):--------- 1-5-3-6-2-4------------------------------------- --------- placed in the center as from top order 6-5-4-3-2-1. with coil on plug.---------- This will help.Thanks.
on Mar 19, 2010 | BMW 330 Cars & Trucks
Tip
What is the firing order for 2004 BMW 325 (E46) 3.0 liter L6 DOHC (M56)?
the firing order for 2004 BMW 325 (E46) 3.0 liter L6 DOHC (M56) is :--------------------- 1-5-3-6-2-4.---------------------------------------------------------------------------------- --------- placed in the center as from top order 6-5-4-3-2-1.with coil on plug. ---------- This will help.Thanks.
on Mar 19, 2010 | BMW 325 Cars & Trucks
How to remove dictionary prediction from motorola l 6
while in the message box or text entry area use ' # ' till u get to see 'ab 1' below the tower on the top left corner of the screen. thats it. u r there..
Dec 22, 2009 | Motorola Mobility L6 Cellular Phone
Tip
What is the firing order for 2004 BMW 325 (E46) 2.5 liter L6 DOHC (M54)?
the firing order for 2004 BMW 325 (E46) 2.5 liter L6 DOHC (M54) is:-------------- 1-5-3-6-2-4.-------------------------------------------------------------------------- --------- placed in the center as from top order 6-5-4-3-2-1. ---------- This will help.Thanks.
ERROR L6
An L6-10 code is a polygon motor failure in the copier's laser unit. It's what flashes the image to the system drum. If it won't clear after shutting down/unplugging the unit for 30+ seconds then the laser unit (the LSU) needs to be replaced. You'll need to contact a trained Sharp service representative to facilitate the repair.
Oct 01, 2009 | Sharp AR-M205 Copier
I had the error message L-4 .can you halp to fix this problem?
L6 is a laser polygon motor fault, you need to replace the polygon motor in the laser unit, but try the reset code first sim 14
May 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
FLASHING ERROR 6 L
L6:The Main PWB sensed a Polygon motor lock signal error. 5-L6 only: Check the connector CN23 on the Main PWB and the wires and connectors on the Laser Module. If connector and wires are not damaged, replace laser module. What that normally means is the laser mirror motor has failed. That normal price for that item is normally over $300. Here is a parts dealer to contact to see if they have it in stock. https://www.partsdrop.com/store/
May 15, 2008 | Xerox WorkCentre XD120F Laser Printer
I need serious help.
overcharge motorola L 6 now its not workking
Feb 14, 2008 | Motorola Mobility L6 Cellular Phone
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
35 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
