Question about Canon P23-DH Calculator
Nothing works...won't reset
Looks like E_._._. on screen
Kenwood 6.1 dvd screen won't turn on, but reset
It appears that you may have battery power but, no accessory power. Check you radio fuse in the vehicle and, behind the radio.
Feb 06, 2013 | Car Audio & Video
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
Iphone4S screen stays blue, won't shut off. nothing works
Hi
Try hard resetting.This restores factory settings on your phone.Be warned though,it will also erase all user data like video images and songs etc.
Here's a video tutorial on how to go about it.
Hope it helps.Thanks!
Feb 19, 2012 | Apple iPhone4 4G iPhone 4
Iphone4 screen goes blue and won't shut off
Hi
Try hard resetting it.This procedure may erase all changes effected on the i phone
Press and hold the power button and the menu button.Wait until the apple logo appears.
Feb 19, 2012 | Cell Phones
Hi I just recently charged up my mp3 player after a long time it's charged but lock screen won't come off I hit the reset still no success
Hello if you see light the back light turned on and see nothing on the screen that mean the frame-wire is damaged and you need to buy new mp3. Or maybe the battery is not working change it as soon as possible and explain to the shop what is the problem. Please rate my comment
Nov 20, 2011 | Samsung Napster YP-910 MP3 Player
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Hi, I have bought this G1 from Ebay, dont know what is wrong with it. when turn on it vibrates & screen remain blueish black, I tried to Factory reset it. everytime you hard reset it, it gives...
HOpe you did the hard reset by pressing and holding home +power and then alt+w .
Does pressing and holding camera and power gives you the bootloader ( Hboot ) screen . IF yes , try reset from there .
ALso CLick HERE for more details .
Aug 06, 2011 | HTC G1
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
Light on top indicates power is on but nothing showing on screen
Hi, try a reset ( push paperclip into hole underneath tomtom ) . if the reset doesnt work then its likely your charger might be faulty and putting too much voltage out and has damaged your tomtom . ( quite common ) .
Good luck .
ps , I have posted solution to this problem many times so it might be worth reading / looking through my other posts .
Dec 31, 2008 | Tomtom ONE GPS Receiver
Canon P23-DH Calculator Logo
53 people viewed this question
old marine
old marine
