Question about GE XL1800 1100 Watts Microwave Oven
WHAT IS THE WATTS ON MODEL jvm1440wh04 - GE XL1800 1100 Watts Microwave Oven
Microwave oven General Electric oven flashing F3 how can I fix this model #JVM1440WH04
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks
Oct 22, 2011 | General Electric Microwave Oven
Adora Space maker XL1800 has problem right now.. it says F3....i bought microwaver since 2004... i cant find trouble shoot book.. i need to know what it is F3?? thanks, Tim Lavelle...
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If you (or someone you know) might want to replace a separately available keypad yourself, I have uploaded a
handy guide with pictures showing you what's typically involved.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number* here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
To see if this is the case for your model, enter your full model number* here.
* To show you this importance of an exact model number, the "XL1400" series included the following specific models:
JVM1410BC001
JVM1410BC002
JVM1410WC001
JVM1410WC002
JVM1420BB01
JVM1420BB02
JVM1420WB01
JVM1420WB02
JVM1421BC002
JVM1421BC01
JVM1421WC002
JVM1421WC01
JVM1430BA01
JVM1430BD001
JVM1430BD002
JVM1430BD01
JVM1430BD02
JVM1430BD03
JVM1430WA01
JVM1430WD001
JVM1430WD002
JVM1430WD01
JVM1430WD02
JVM1430WD03
JVM1431BA01
JVM1431WA01
JVM1440AA01
JVM1440BA01
JVM1440BD001
JVM1440BD002
JVM1440BD003
JVM1440BH01
JVM1440BH02
JVM1440BH03
JVM1440BH04
JVM1440CK01
JVM1440LK01
JVM1440LK02
JVM1440SH001
JVM1440SH01
JVM1440SH02
JVM1440SH03
JVM1440WA01
JVM1440WD001
JVM1440WD002
JVM1440WD003
JVM1440WH01
JVM1440WH02
JVM1440WH03
JVM1440WH04
JVM1441BD001
JVM1441BD002
JVM1441BD003
JVM1441BH01
JVM1441BH02
JVM1441BH03
JVM1441BH04
JVM1441CJ01
JVM1441CJ02
JVM1441CJ03
JVM1441CJ04
JVM1441SH001
JVM1441SH01
JVM1441SH02
JVM1441SH03
JVM1441WD001
JVM1441WD002
JVM1441WD003
JVM1441WH01
JVM1441WH02
JVM1441WH03
JVM1441WH04
JVM1442AA01
JVM1442BA01
JVM1442WA01
JVM1443BK01
JVM1443BK02
JVM1443LK01
JVM1443LK02
JVM1443WK01
JVM1443WK02
JVM1450AA01
JVM1450BA01
JVM1450BC001
JVM1450BC002
JVM1450WA01
JVM1450WC001
JVM1450WC002
JVM1451AA01
JVM1451BA01
JVM1451WA01
JVM1460AA01
JVM1460BA01
JVM1460SA01
JVM1460WA01
JVM1490BD002
JVM1490BD003
JVM1490BD03
JVM1490BH01
JVM1490BH02
JVM1490CD002
JVM1490CD003
JVM1490CD03
JVM1490CH01
JVM1490CH02
JVM1490SD002
JVM1490SD003
JVM1490SD03
JVM1490SH01
JVM1490SH02
JVM1490WD002
JVM1490WD003
JVM1490WD03
JVM1490WH01
JVM1490WH02
Oct 01, 2010 | GE XL1800 1100 Watts Microwave Oven
I have a microwave and I am not sure of the wattage . The model # is JES738WJ02 And seriall # is DS991786u could you please help me find the answer to how many watts this product is. Thank you
Your microwave oven is 700 watts. Its printed on front of the owner's manual. If you no longer have an owner's manual, you can go to managemylife.com and download or print a copy for FREE. Just type in the model number you provided under the "Manuals" link. Your manual is listed in .pdf (Adobe) format. I hope this help you.
Feb 28, 2010 | Microwave Ovens
Numbers 4,7,8,9,0 and Beverage on pad do not work. Others do work, do I have to replace the oven? (Spacesaver JVM1440WH04) Over stove oven installed in Feb 2007, in use 4 months each year. This problem...
No you can have the keypad replaced. It may be something as simple as a dis-lodged keypad ribbon connection where it mates to the control panel recepticle. If you look here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 there are several model numbers it seems you did not provide all of the numbers but the keypad is the same. The key panel here is $75.00 http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 Then you add a service call or shop charge your looking at well over a $100.00 repair. Your call on how to proceed. Good luck.
Jan 12, 2010 | GE JVM1440 Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave fan started and f3 shows on the screen the only was to stop the fan is to unplug it. nothing on the panel works. what does f3 mean?
> JVM1440WH04
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is part number WB07X10951 and you can get it here for $93.20 (compared to $137.25 from GE!).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
The you unplug the keypad (as per the attached photo) and move the circuit board into your frame.
Jul 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
