Question about Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum
Over heating switches off
Stops running for a while
When I vacuum with my Riccaar after 8 minutes it stops running and have to wait a while the press the thermal switch. Could I have a bad thermal switch?
If the switch was bad it likely would not run at all. It is probably getting hot because of a clog somewhere.
Aug 17, 2017 | Vacuums
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Vacuum runs 10-11 minutes then stops if you unplug for a minute it then runs for another ten or so minutes then stops again I heard it was the bypass switch what can I do
Hi, I would say the motor is overhesting and there is a heat sensor in the motor that shuts it off w3hen its labouring. Check your hose for a clog . If that does not help check the filter aorund the motor to see if it is clean. Hope this helps. Chris
Feb 21, 2011 | Numatic HVR200P Bagged Canister Vacuum
Trips
The switch could be bad. Make sure there are no clogs anywhere that could be causing it to overheat. Try to bypass the switch and run it just long enough to see if you can go longer than the normal 5 min. you're getting. If you can then replace the trip switch. Do not continue to use the machine without the trip switch operating properly or it could catch on fire.
Jul 20, 2010 | Beam Industries 2900 Serenity Plus Central...
I have an easy flo vacuum model # 199C and it won't shut off. It started out as an intermitent problem but now will not shut off when the hose is unplugged, nor when the off/on switch on the main unit is...
Remove the low voltage wires (top left) if the vac unit still runs the problem is with vacuum
if the Vac stops running then there is problem with the low voltage wires in the home possible short some where in the system Chech the inlet doors first. Easy Flo vacuums have a lifetime warranty call 1800 easy Flo.
Feb 13, 2010 | Easy Flo EF1500 Vacuum
Turns off after 10 minutes of normal useage then comes back on 20 minutes later
it has a cutoff switch two stop it from over heating check it isent blocked up sumwhere in the fillters or the pipes
Oct 20, 2009 | Kirby G6 Bagged Upright Vacuum
The motor stops while you are using it and the stand by lights up
you are over heating the motor ...that is caused by low airflow ... make sure the bag is not full, hoses not clogged and secondary filters (sometimes on the output side) are not clogged ... make sure there is lots of air going thru the motor .. the motor cant run long without air to cool it ... it has a thermal switch that trips when it gets too hot .. the thermal switch resets itself when the motor has cooled ...
Aug 05, 2009 | Electrolux Vacuums
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum Logo
16 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
