Question about Casio G'zOne Rock Cell Phone
Mic is not working right
Microphone not clear and weak
Getting alot of static through my mic
I own two MXL 990's and have had no issues with extra noise of any kind. I would suggest checking or replacing the mic cables with new or known good ones. Also I don't know what you are connecting it to but a weak or noisy Phantom Supply could also cause extra noise.
Mar 08, 2014 | MXL 990s Professional Microphone
My AKG C1000S shows a weak signal from one side of the two stereo channels when I use an XLR going to a 1/4 inch Stereo jack. Does the mic only work properly with a Mono jack?
You have connected the mic improperly. You'll need an XLR to 1/4" transformer to properly match the impedance, then run into a mono channel.
Mar 15, 2012 | AKG C1000S Professional Microphone
I recently bought the PC Desk top Miocrophone 600. Plugged it into the back of the computer were mic is at. Nothing Help!!!
Double Click the speaker icon on the right hand bottom ( next to clock ) of the desktop screen.Click options, then click properties. Form the drop down list tick MIC.Now your **** socket is active but by default the MUTE box will be ticked. Untick to enable it. Adjust MIC level for clear sound.
Mar 10, 2011 | Logitech (980240-0403) Microphone
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Microphone not working
The microphone level can only be adjusted in certain games. Have you tried using the mic in any other games? Most likely, the mic is simply defective; I have heard of more than one case of manufacturing defects with Nintendo DS microphones. How long have you had the system? If it is still under warranty, Nintendo should fix the system for free.
Jan 27, 2008 | Nintendo DS Console
Does not work on Skype and Messenger
In Vista, right click on the speaker icon in your system tray (usually located at the bottom right of the screen) and select "Recording Devices". Be sure that your microphone is enabled in this list. In Skype and MSN, find the audio hardware setup, and make sure to select your mic-in port into which the mic is plugged.
Dec 12, 2007 | Cyber Acoustics CV-1064 Microphone
adjust the proximity of microphone or call nintendo helpline 08706060247 which has a 24 month warranty
Oct 24, 2007 | Nintendo DS Lite Console
Acknowledging Microphone
Sounds like the mic is bad. The only way to confirm this is to plug a different mic into the computer and see if that works. If the second mic gives no sound then the computer may have an issue. Hope this helps.
Nov 04, 2006 | Logitech (980240-0403) Microphone
Casio G'zOne Rock Cell Phone Logo
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
