Question about Sony Car Audio & Video
Sony cdx gt 350
Faceplate don't work anymore. Tried cleaning the contacts,resetting it,that didn't work.
SOURCE: Sony CDX-MP40 only works after hitting reset button
If you dosn't find a solution, then I'am very interested in buying the faceplate for this unit. batman@galnet.dk
Posted on May 25, 2008
thefazool
  • 3 Answers
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
Posted on Dec 15, 2008
etirbynnor
  • 655 Answers
SOURCE: My Sony CDX-C680...
Hello greggerika,
It's possible that the "illumination" wire is not connected or connected improperly. It's also possible that the front panel electrical connections are not making proper contact. Remove the front panel and gently clean the contacts with a pencil eraser.
Also, the CDX-C680 allows you to select either green or amber illumination. One or the other may be defective. Try changing it. Press SHIFT - press "3" (set up) three times - press "5" (right arrow) to change the setting. Also check the setting for "dimmer". ON will result in a dimmed display at all times. AUTO will dim the display whenever the headlights are turned on (if the wiring is connected properly). OFF will result in the brightest display at all times.
Hope this helps.
Posted on Jun 14, 2009
SOURCE: Sony CDX-GT30W faceplate
I have a faceplate for a sony cdx-gt30w. You can have it for whatever it costs for me to mail it to you. Do you still need one. I noticed you posted this a loooong time ago.
Posted on Aug 18, 2009
dancandoit
  • 436 Answers
SOURCE: Sony Xplod CDX-M610 has blank faceplate
It sound like it has jammed in the mechanism, try pressing the reset button on the back plate, if this dont work you may need to remove the radio or fuse otherwise it may flatten your battery.
Dan.
Posted on Nov 25, 2009
The buttons on my Sony cdx-l410x aren't working. How do I fix it?
If it's a detachable face plate then carefully clean the contacts on the chassis and faceplate and inspect them look for bent or damaged connectors. A penciler as works great to clean contacts if this type or a q tip dipped in rubbing alcohol. If not you may need to disassemble the faceplate and clean the circuit board. I have seen, in vehicles where a drink holder is right at the radio, over time drink will splash into the face and overtime cause malfunctions. If that still doesn't work then either the faceplate is bad or the chassis is bad. Both have microprocessors that communicate to one another. At that point it is probably cheaper to replace than repair
Aug 08, 2016 | Sony Car Audio & Video
None of the buttons on the faceplate seem to work except OFF. The remote works and still can control all functions on the radio. I have read the manual and don't see anything about the faceplate locking or...
check the gold contacts on the back of the face and the unit also check the release mechanism theres a little black button (not the reset) that when face is pressed up against it it activates power to the gold contacts thus powering the buttons
Dec 14, 2009 | Sony XPLOD CDX-GT200 CD Player
Display issues on CDX-FW570
YOU MUST RESET THE PLAYER BY PRESSING A RESET SWICH LOCATED ON FRONT SIDE OF YOUR PLAYER. PRESS THE RESET SWICH FOR 10 SECONDS WHEN THE POWER SUPPLY IS ON.
IT MAY SOLVE YOUR PROB.
BEST LUCK
REGARDS
KETAN PATEL
Feb 11, 2009 | Sony CDX-FW570 CD Player
Sony XR-C2600 car stereo stuck in demo mode
Sony XR C2600
  • Press release button on faceplate.
  • Remove the faceplate.
  • Clean the contacts in system and faceplate with alcohol.
  • Voila, all button works now
Bullet Sankar India
Feb 05, 2009 | Car Audio & Video
Stolen faceplate
the GT-200 is the cheapest of the sony line. A new radio can be obtained for under $50. A faceplate direct from sony would be approximately the same amount. Check eBay or Craigslist for a used one.
Dec 21, 2008 | Sony XPLOD CDX-GT200 CD Player
Sony Xplod cdx-gt310
it is most likely shorted faceplate, either send it to be repaired heres address:http://www.xplodsony.com/support or buy a new one at wholesale at this address:www.godspeedaudioheaven.com
May 20, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Mar 09, 2008 | Sony CDX-MP40 CD Player
Faceplate not working
Try disconnecting the unit completely.
Nov 09, 2007 | Sony CDX-F7700 CD Player
Cd Player Lights Up No Music Coming Out Of Speakers
try resetting it, open faceplate, with pen tip ,press reset button
Sep 08, 2007 | Sony CDX-C5000X
Functions do not work even after resetting.
try cleaning the faceplate pins on the faceplate and the deck with alchool and q-tips, that dont work id start with peanuts :-)
Don
Nov 27, 2006 | Sony CDX-R3000 CD Player
Car Audio & Video Logo
12 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
