Question about Garden
Not keeping the pressure
Not keeping pressure
How can i test a fuel pressure regulator, and fuel pressure even if i can't get the car started?
The regulator only controls pressure, so it either blocks return to the tank or allows all pressure to flow back. If it blocks flow the pressure would be too high, wide open would keep pressure low.
You connect a pressure gauge to the system and if it is low, block the return line to the tank to recheck.
You may have to bypass the pump relay to keep the pump running during the test.
Mar 19, 2016 | Cars & Trucks
Low tire pressure light keeps coming on, even when tires are at correct pressure
First, check the tire pressure of the spare. If all tires are properly inflated, then one of the sensors are bad and must be replaced.
Mar 16, 2015 | 2006 Jeep Liberty
Why 97 jeep grand cherokee 5.2 wont keep fuel pressure?
There might be a leak in your fuel line connected to the fuel filter, also check the gasket on the gas tank cap, it might be worn out and would cause the system to drop pressure.
Oct 14, 2014 | Vehicle Parts & Accessories
My oil pressure sensore keeps going off
If you mean the low pressure warning on the cluster, is the oil pressure dropping below normal range ?
You may need to have the oil pressure sensor replaced or have the oil pressure checked with a mechanical gauge.
Aug 08, 2012 | 2005 Cadillac CTS
My well keeps running i replace the pressure switch and the well starts working properly this happens every 6 months i have replaced the well , jet , and bladder tank why does this keep going on
by keeps running I assume that the presure switch doesn't cut out at the desired pressure and replacing the pressure switch solves the problem probably the contacts in the pressure switch are becoming welded if it worked for years and then this just started then if the pump has a capacitor start ( box inside the house between the pressure switch and the pump wires) you may want to cosider replacing that component and well your poking around verify that the rating of the pressure switch matches your pump requirements amps volts ect..
Good Luck
Oct 08, 2009 | Plumbing
Will not release pressure and dies
Your unloader valve is not functioning. Take it apart and make sure it all the parts are able to move freely under the spring. You may need a new o-ring or two if you see damaged ones.
Aug 02, 2009 | Cam Spray 25006HT 2500 PSI Cold Water Gas...
My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
SOUNDS LIKE YOU HAVE A LEAK DOWNSTREAM PROBABLY UNDERGROUND. THE PUMP HAS NO REASON TO COME ON EXCEPT TO BUILD THE PRESSURE BACK UP. HOPEFULLY YOU HAVE A GAUGE IN THE DISCHARGE LINE YOU CAN WATCH IT DROP AFTER THE SYSTEM SHUTS OFF. HOPE THIS HELPS, JODY
Apr 27, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
