Question about Fisher and Paykel Refrigerators
Butter conditioner I immersed the butter conditioner while cleaning it. What will happen if I put it back in?
    Sergeant:
  • 446 Answers
Let it sit to dry out so it will not short
Posted on Mar 24, 2014
How to use
Put popcorn in bottom up to where the ring in bottom levels off for a maker full or less if you don't want a maker full. Cover with popcorn oil, I use the butter flavor oil. Put some butter inside of lid compartment and put lid back on butter compartment. Now just put lid onto popper and plug in. The light on side will come on and popper will start to heat. You will then hear it start to pop. Popping is finished when light on side goes out. Carefully lift the whole popper and shake right side up and then turn upside down and shake. Remove bottom, add some popcorn salt if you like and enjoy it right out of the lid. Delisious!!
Aug 13, 2012 | Hamilton Beach Butter-up Corn Popper Self...
I have a Sylvania decorative stove with heater model QC 889 that sometimes makes a loud noise when "heat" is on. It doesn't happen when just the "fire" is on. Is there anything...
It's been a while..but the problem is lubrication. All screws need to be removed from the entire back an heater unit. There is a 1/2 in black rubber plug thay must be pryed out carefully (butter knife?) Pop out black plastic from the rubber and lub the center liberally with vasciline. Put everything back together while cursing the "engineer" who "planned" this. PS good time to change the light bulb.
Sep 06, 2011 | Heating & Cooling
How to change or clean the filter and where to download a manual
DeLonghi has the manuals for their portable air conditioners here: http://delonghiusa.com/support/product_manuals/5#table-jump . The direct link to the PAC C120 manual is http://delonghiusa.com/support/sites/default/files/product_manuals/m-PAC+C120.pdf .
Before cleaning, turn off the air conditioner. To clean the filter, pull it straight up from behind the top of the air intake (on the back of the PAC C120). Vacuum off the filter. If it is very dirty, immerse it in warm water and rinse several times. (The water should not above 40 degrees Celsius (104 degrees F)) several times. Then allow the filter to air dry. Slide the filter back into the air conditioner and turn the unit back on.
I hope this helps.
Jul 17, 2011 | DeLonghi PAC C120 Portable Air Conditioner
I had a stick of butter laying on top of my bunn coffee pot and some butter leaked through the vents. the coffee tasted terrible so i cleaned it with vinegar and ran about 10 pots of clear water through...
Believe it or not I had a customer once that left 6 pounds of butter on top of one of our brewers. They had it cleaned up on the outside so it took me a while to figure out what had happened but I could taste the rancid oils.
We ran about 20 pots of just water through it... make sure you let it heat back up before each one. I think the only thing vinegar might help with would be lime/calcium build up so I wouldn't think it helps this particular situation.
Dec 21, 2010 | Bunn BT10B Coffee Maker
We spilled melted butter into the base that holds the kernals. Now we get black smoke when we plug it in. I tried running it on empty for awhile, but the smoke continues. Can we remove the top and clean...
you can open it but not from the top. unscrew the bottom and take out the heater and clean out the Popper without using any water or soap just a toothbrush and cloth. it will take more then one clean out to get it to stop smoking (took me 3 times). put it back together place a plate under it to catch butter and run it for 10 min. to get hidden butter to melt and seep out of hidden spaces then repeat cleaning.
Sep 11, 2010 | Presto 04820 PopLite Popcorn Maker
Freezer area smells and ice cubes and butter taste off?
It sounds like the ice maker if equiped. Remove Ice bin and clean out,and try a lite spray of bleach or vinegar (don't mix) If the smell is still happening and comming from ice you may want to install a inline filter.
Jul 26, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
No instructions but wanting to know where do you put in the butter for the back to basic stove top popper
The manual says, place butter in cup, hook cup onto the rim of the pan below the "butter cup"marking on the lid, and the butter will melt and drip evenly onto the popcorn as it pops. I haven't tried it; hope it works for you.
Apr 01, 2010 | Back to Basics Popcorn Popper (PC6)...
Dropped phone in a bowl of liquid
REMOVE THE BATTERY!
*Choice one- Methyl Alcohol
Clean the circuit with Methyl Alcohol
  • Dip a q-tip in the alcohol and squeeze the q-tip.(you want it to be almost dry)
  • Very carefully clean the circuit and allow it to dry, it is important that you clean around the medal to prevent short circuits.
*Choice two- Rubbing Alcohol
Clean the circuit with Rubbing Alcohol
  • Rubbing alcohol has a slower evaporation rate so you need to wipe the area with a clean q-tip after cleaning it with the alcohol.
If this dose not work you need a new phone, good luck.
Aug 15, 2009 | Motorola Mobility RAZR V3
Electric immersion heater keeps cutting out
Sounds to me like you have a bad thermostat. You should be able to give a model number to any local plumbing supply place and get one for replacement. make sure power is of the unit before replaceing.
Feb 02, 2009 | Carrier TSTATHCP Programmable Thermostat...
Auto oven cleaner
I removed the two screws that hold the warning plate that has the latch coming through it. This allows the oven lock lever and latch to move around. you will see the shiny base of bracket that holds the lever and latch mechanism. I took a plain butter knife and pushed back the insulation to see the switch. I then put the butter knife against the switch and rapped it fairly hard with the screwdriver handle 3 or 4 times. Put the plate back and screws back. Turned on the breaker and was good as new.
Tools needed.. butter knife and nutdriver to fit screws.
Jul 10, 2008 | Kitchen Ranges
Refrigerators Logo
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
