Question about Winegard HD7697 High Definition VHF/UHF Series TV Antenna HD7697P
Not receiving signal from wcyb channel 5 on winegard hd7697 antenna
Cant pick up channel 5 pbs comes in clear along with channel 11 ,11 tower in same direction and distance as 5.
  • 53 Answers
Try installing a tv signal amplifier on the line from the antenna just before the tv. Tv stations put out differing amts of power, one could be stronger than the other.
Posted on Mar 22, 2014
Did get wcyb now I don't using the same indoor antenna
Antennas now take very little movement to get a connection. You may need one with an amp as there maybe some interference. Signal capture now in the digital age is much mote touchie than in the old analog days..
Aug 02, 2017 | Televison & Video
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
My tv says no signal on one channel, how do i get that channel back ?
If you are getting an OTA signal, you should check your antenna, any amplifier or splitter and the station's status. The "No signal" message indicates that the signal is not strong enough to be resolved by the tuner.
1) Is your antenna pointing in the correct direction? Outdoor antennas can sometimes turn in the wind. Reset the antenna to the correct direction.
2) If you have a splitter dividing the signal between TVs or other devices, try a direct connection to the one TV that isn't receiving the channel. Similarly, if you have an amplifier in the system, try using the antenna without it. (I have seen an amplifier become a filter for select channels when damaged.) The only solution is to replace the device or omit it. (In my case, some channels require amplification; thus we replaced the amplifier.)
3) Has the station's local transmitter/repeater been damaged? Check their news feed. Towers fall and transmitter components can fail.
You could try and see if another tuner picks up the signal. Some low end tuners are more sensitive to signal strength. If you are getting the station from another source, check with the provider. We recently lost some of the local PBS stations due to problems with the cable provider's feed. Only one TV is connected to the set top box.
I hope this helps.
Feb 13, 2015 | Televison & Video
Message on screen
OTA stands for "over the air"and for a std TV it is searching for VHF/UHF signals as beamed from satellite. If the antennae is properly mounted and connection don't have any sulpher deposits, then the tuner has to be replaced. As far as the antennae, the basiscs are:
Based on this information, you need an antenna that receives high vhf and uhf. KVIE (ch 9, PBS) and KXTV (ch 10, ABC) are high vhf and not receivable with the CM 4220. I would recommend the Winegard 7694 or HBU-22 antennas. The Winegard has higher gain and is a 5 inches shorter than the HBU-22. Shorter boom length and higher gain will come in handy with an attic install. However, 7694 is more expensive ($60 vs ~$40).........................................sodeep
Sep 30, 2009 | Televison & Video
I just purchased an amplified indoor HDTV Antenna to better receive HD tv. Is the LCD display supposed to be on all the time??? How can I get better reception from a broken picture even rotating the...
I don't know in what area you live & therefore how strong your reception area will be, but as a general rule an indoor antenna is never the best type of aerial to have to receive digital signals, you will always find that you pick up some good strong channels but more often the rest of the channels will be poor or non-existant & will constantly break-up/freeze etc. The best advice would be to try & fit an outdoor antenna if possible.
Jul 15, 2009 | Televison & Video
HELP !!! I HAVE 5 CONVERTER BOXES AND STILL "NO SIGNAL" APPEARS.
you could try waiting or .. make sure you tv is in "digital" not "analog"
May 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
biigg53566
Feb 19, 2009 | Insignia Digital-to-Analog Converter for...
Not picking up Digital signal from box but can receive it analog
So many factors could be affecting your reception. Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital. Your converter box when turned on will probably not pick up the standard signal. The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get. Let me know and I can help further.
lone99star
Jan 09, 2009 | Emerson EWL20D6 Television
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
Indoor antenna problems
I don't know the menu system on your model, but you have to check that the tuner is in the proper mode. Also, some of the new TV set models cannot receive a standard analog TV signal from its tuner.
As for the distance from the transmitter sight, this depends mostly on the antenna quality, antenna location, the power output of the transmitter sight, compatiblity of the TV to the received signal, and also the capability of the TV's tuner.
Modern TV sets are really designed to be used with a satellite or cable TV box with their respective service.
Terrestrial TV is dying out, and in a matter of a number of years, it will be gone.
Jerry G.
May 24, 2008 | RCA F25645 25" TV
Winegard HD7697 High Definition VHF/UHF Series TV Antenna HD7697P Logo
182 people viewed this question
Top Winegard Electronics - Others Experts
Are you a Winegard Electronics - Other Expert? Answer questions, earn points and help others
