Question about Raypak Pool & Spa
Cannot change to remote control touch pad does not respond
    Top Expert:
  • Raypak Master
  • 5,775 Answers
Make sure hooked up to pool and spa common then put on t stat or remote
Posted on Apr 27, 2016
The touch pad on my 990 legacy remote does not work?
The touch pad does not respond
Claudia, dismantle and try to clean or just replace with a good universal remote.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Televison & Video
F21
This error occurs if the touch-pad/LED assembly is not able to
transmit/receive data to/from the central control unit (CCU).
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Mar 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Control panel not responding
Your spa side touch pad/ topside control panel is failing. It is only a "Communicator" the buttons are shorting between them. This is usually the problem when symptoms are manifest like yours.
Jan 26, 2014 | Dream Maker Spas Pool & Spa
Washer gives code F22. I replaced the door lock mechanism but it still will not start.
Hi, F-22 means that the CCU /touch pad/LED assembly unable to transmit/receive
data to/from the CCU central control unit
Possible causes/procedure:
Your model's tech sheet gives error codes and remedys.
Jun 17, 2011 | Kenmore Elite HE5t Washer
Error message F22
HI. This error occurs if the touch pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touch pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch pad/LED is responding.
3. Check wire harness connections to the touch pad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Which will be the actual CCU, if the wirineing harness is ok, and connected properly)
Feb 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error f 21? what does it mean?
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/proceedure:
More Here
Jan 12, 2011 | Washing Machines
Code f21
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the touch-pad/LED assembly and Central Control Unit (CCU).
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 keeps on flashing???????????????????????????
This error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Apr 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22
This (F21 or FF22) error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
See the full list of codes at:
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182277.pdf
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
Pool & Spa Logo
41 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
