Question about Rival 3355 5-Quart
Heat knob the heat knob broke and needs replacing.
The on/off knob broke. hoping to find a replacement
replacement small appliance knobs usually available at hardware stores, press the helpful button.
Jan 19, 2016 | Crock Pots & Slow Cookers
The knob on lid broke off. Can it be replaced?
Yes, visit down to Home Depot. They have a large range of metal, plastic and wooden knobs in the hardware section. Take the lid with you to check the size of the screw.
Dec 10, 2015 | Crock Pots & Slow Cookers
I have a model SCO-150 crock pot. When I turned
Well stocked hardware stores have knobs that fit the heat controls on units like the Corningware slow cooker. That's either a local hardware store or a "big box" store. And Radio Shack or another big electronics parts places might, too. Notice the shaft of the control. It's almost certainly round with a "flat spot" on it. The flat spot is manufactured on the shaft of the control so the knob will have a place to "grip" the shaft and not slip.The knobs are pretty standard in the electrical industry. They're used for stuff like light dimmers and such. If you can measure the shaft, you'll probably find it's 1/4" in diameter - a standard size. Call your local True Value or Ace Hardware and explain the problem. It's almost a sure bet that they've got a solution. Make a measurement and make a call. If they've got one, go ahead and pack your cooker in with you, just to be sure. They can check the fit. One trip is all it should take. The staff at the hardware store is waiting to help you. They want you to call.
Mar 18, 2010 | CorningWare Crock Pots & Slow Cookers
The lid fell and the knob broke. can i get a replacement.
In most cases you can. http://www.abtecparts.ca/cknobs_&_cleaners.htm lists some universal replacement knobs...you might see if any of those will work.
Nov 28, 2009 | Dualux RAN109 9-Quart
White knob just broke off rival 37601 glass lid crock pot . need replacement
I found universal replacement knobs at:www.goodmans.net. Thank you for your help.
Jul 09, 2009 | Rival 37601 6-Quart
Slow cooker Model SCO-150 switch knob broken
ince replacing the lid and knob will cost several dollars plus postage I recommend purchasing a new one. That way you have new electronics and a warranty which will assure that you have a cooker for at least a year.
Apr 05, 2009 | Crock Pots & Slow Cookers
Lid Knob
Contact manufactuer for a replacement handle. You should find the toll free number (or) website in the users manual. If you no longer have the manual type in www."the manufactuer".com
Your crock pot may still be under warranty (or) they may even send you the handle free of charge, who knows
Nov 30, 2008 | Rival 38601 Smart Pot 6-Quart
Control knob
Contact the manufacturer. They have replacement parts.
Sep 17, 2008 | Select Brands SC-25 2.5-Quart
Handle on crockpot lid broke off.can I replace it at store where purchased?
I have had the same problem. Spoke to rival customer service and they no longer sell replacement lids for model number SCE502. I've read to take the screw from the knob to a hardware store and then find a knob which will fit it.
Someone else suggested that if the knob is mostly intact, ask hardware store for araldite glue
Dec 08, 2007 | Rival 3755 5.5-Quart
Rival 3355 5-Quart Logo
29 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
charles
Irene Tulloch
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
