Question about Home
Dont know if symbol on casserole means oven or hob use
Symbol is 6 lined in shape of large C or incomplete circle
bobotfel
  • 236 Answers
SOURCE: Centrex air conditioner
Here are some icon that may help you.
COOL- this icon cool your room.
Dry- this icon control the humidity in your room but limit the coolness in your room (24deg C).
Fan- this icon run for fan only.
Heat- this icon heat your room.
Posted on Mar 12, 2008
  • 1462 Answers
SOURCE: meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Posted on Nov 05, 2008
  • 203 Answers
SOURCE: what are meaning of the symbols on the fuse box
what is not working you should be able to see the blown fuse if not take 1 out check it if not blown replace it and repeat till you find blown one. if this helps please rate. joe
Posted on Nov 21, 2008
  • 120 Answers
SOURCE: 2 Dashboard symbols stay lit, but don't know what they mean?
press your parking brake lever all the way down then check your brake fluid level. if its low, then add.
Posted on Dec 31, 2008
SOURCE: CIRCLE SYMBOL with dashes around the outside what does this mean?
Brake pads
Have the brake pads checked
immediately.
dc39396.jpg For your own safety: use only
brake pads that BMW has
released for your particular vehicle
model. BMW cannot evaluate nonapproved
brake pads to determine if
they are suitable for use, and therefore
cannot ensure the operating safety of
the vehicle if they are installed.<
Posted on Aug 24, 2009
Testimonial: "Thank you so much. I guess i shouldnt be driving it around at all then until i get it fixed?"
Cooker been on for a hour on high. Still not very hot, no steam. has a large roast in it is that the difference ?
Crocks do not bubble and steam like pans on the hob or oven casseroles, they cook on a very low heat. It will be fine if you have followed instructions
Mar 13, 2015 | Crock Pots & Slow Cookers
Halogen tabletop oven
You can use any oven-safe dish that will fit inside the oven (preferably, with the low rack in place). I've seen 3 qt round casseroles that will fit when you aren't using the extender. (For example, this should fit: http://www.crateandbarrel.com/dining-and-entertaining/casseroles/lucerne-3-quart-casserole/s512853 ) Some casseroles are sold with non-oven safe lids. Make sure that you check the temperature range for the specific dish. Some are only rated to 400 degrees F.
Unfortunately, I do not know of any sources that sell the accessories separately.
I hope this helps.
Jun 03, 2013 | Fagor 12 Quart Halogen Tabletop Oven
We just moved into new flat with a whirlpool oven Model No: 6AKP524/1X. There's no manual. What are the 4 buttons on top/front for.
Unfortunately we are unable to offer assistance to those residing outside of the United States. Please visit http://www.whirlpool.com.au for assistance in your region.
Jun 09, 2017 | Whirlpool Ovens
What is the difference between a stew and a casserole?
A stew is cooked on a stove or over a fire and a casserole is cooked evenly in an oven. As well, casseroles are cooked either covered or not, while stews are usually covered so they don't evaporate.
Jan 14, 2013 | Home
I have a red dash warning light (no manual) & warning ping when I start up engine. Symbol is like an exclamation mark in circle with outside incomplete circle-lines Cheers
this light for coolant level indicator top up coolant level then s.w off and on , check for coolant leakage may be leakage from radiator sender.
Jun 18, 2011 | Volkswagen Golf Cars & Trucks
Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Oct 03, 2009 | Ovens
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob. I also have the red key about the on switch and cannot swithc it on!
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
May 28, 2009 | Neff 23 in. T4343 Electric Cooktop
Zannusi built in oven
Solid line at top indicates the grill. Two indicate the oven.
Sep 21, 2017 | Zanussi ZHQ575 Electric Double Oven
Meaning of symbols on oven setting.
Nov 05, 2008 | Smeg SE250XUK Stainless Steel Electric...
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Home Logo
554 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
