Question about Apple MacBook Pro MB991LL/A 13.3-Inch Laptop Notebook
Command s not working
Get around it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 124 Answers
An errant keyboard shortcut could be the cause. To check this, go to System Preferences, then Keyboard and click the shortcuts tab/pane.
Cheers.
Posted on Sep 28, 2014
I need help opening iphoto
Make sure you have the latest updates.
Click the Mac App Store on your Dock and make sure everything is updated.
If everything is current, open iPhoto while holding down both the Command and Option keys. It should then ask permission to rebuild.
If that does not work, make another post with what you have tried and someone will help.
Mar 29, 2015 | Computers & Internet
Why do I get "There was a problem sending the command to the program" when opening Word?
Go to 'Properties' (right click on the program), go to Compatibility, If the program is running in Compatability mode, uncheck this option and see if that resolves the problem.
Dec 11, 2012 | Microsoft Office Professional 2007 Full...
What is command line interface?
A command line interface is where you enter text commands to a computer to make it do things. If you are on Windows and you hold the Windows key and press R, then type "cmd" (without quotations) in the dialog box there, it will open a command line terminal. Try typing "dir" (no quotations) and pressing enter. This is a simple command that shows the contents of your current directory.
Further reading on command lines:
http://en.wikipedia.org/wiki/Command-line_interface
There are advantages to the command line mostly based around the idea that it gives you a bit more control over what you are doing. Graphical interfaces (GUIs) sacrifice a bit of functionality for the sake of showing you what you are doing visually.
For instance, think of a folder on your computer with a hundred files in it. Say you want to rename all those files to consecutive numbers or by some other schema. In a graphical interface, you would have to click each one and rename it, but with a command line, you can navigate to that folder and tell the computer to run a simple script that renames all of them with a few simple text commands. Renaming a hundred files might take you 20 minutes in a GUI but typing out a few simple commands might take you only 30 seconds.
In non-Windows operating systems, especially UNIX- and Linux-based ones, ability to use the command line is a valuable and almost required skill, because you have access to the deepest workings of your computer.
Oct 25, 2012 | Microsoft Computers & Internet
Recorder is set to DVD command mode 1 and remote is set to DVD command mode 3 . Remote will not respond so i can not get to menu to reset. Is there any way around this problem
There is a manual for this model available in pdf format unless you have the original instruction book. Page 23 outlines 'command mode' where you can try pressing ENTER and the corresponding number buttons simultaneously on the remote for more than 3 seconds while pointing RC at the recorder. In your case, because your recorder is set to command mode 1 - press ENTER and 1 together on the remote. This should allow you back into the on-screen menu to revert the command mode back to 3 (which is the default) and it should work.
The online pdf manual for this model: http://www.docs.sony.com/release/RDRVX560_EN_ES.pdf unless you still have the original. Pages 22-24 show some of the setup procedures. The pdf is not very big so you can save it for future use if needed.
Feb 01, 2011 | Sony RDR-VX560 DVD Recorder/VCR
I cannot install Missile Command on a x64 Windows Vista PC. Please help?
You should be able to. I did on my Alienware Aurora R4 Windows 7 64-bit system. (a little overkill there - I know) The CG cutscenes won't work because you need the now defunct, and discredited for being security holes, Indeo codecs, but there are ways around that, too, possibly.
You'll have to say more.
Nov 17, 2010 | Hasbro Interactive Missile Command for...
Mfc 7820n - scan
I would imagine only they can provide you with that.
Sep 29, 2008 | Brother MFC-7820N Laser Printer
How to locate a virus using command prompt?
I don't know how to locate a virus using command prompt. Is there any reason why you want to do that?
I bet there are some virusscanners around which can be controlled using the Command Prompt. You can just install a free scanner like AVG AntiVirus Free Edition. And let it scan in Safe Mode.
Here's a link to it:
[Grisoft AVG AntiVirus 7.5 Free Edition]
I hope this helps. Please rate.
Greetings,
DarkNeogen.
Feb 11, 2008 | Computers & Internet
Trying to set the offset on Datamax Prodigy Printer
Add the OFFSET command (Oxxxx) command to beginning of the data. A value of around 0700 usually works.
The prodigy+ does not have any other facility for setting the tear-off position, nor is the effect of the O command persistent.
I don't know where you're seeing that offset value since the printer cannot report it. If it's in your printer driver, then try adjusting the value in the driver itself.
Steve
Jan 07, 2008 | Epson Printer
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Apple MacBook Pro MB991LL/A 13.3-Inch Laptop Notebook Logo
42 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
