Question about Sony Ta-sa200wr S-air Surround Amplifier Ezw-rt10a Wireless Transmitter
Rear box won't power on. Is there a reset button
It powered on before we moved & now it seems as though it's not getting any power to turn on but all the electricity outlets in the home work
  • 4234 Answers
SOURCE: Must reset the camcorder to power on.
Sony has a fixed repair cost which includes parts. That is where the $211 comes from. If you have a major problem, you win as the boards inside can easily cost more than that. If you have a minor problem, well...
That being said, there are no other symptoms other than the need for a reset? This sounds like a logic problem. The power-on should be resetting the whole camera anyway. I'll look up this model tonight. As far as the shutdown is concerned, this is normal. If the power-up sequence fails (not performing the reset constitutes failure), the unit shuts down to prevent damage. So at least that part functions correctly.
Stay tuned...
Dan
Posted on Apr 09, 2008
  • 4234 Answers
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Posted on Jul 07, 2008
Nickstar19
  • 417 Answers
SOURCE: Our wii is not powering
you may of blown the fuse or the power adapter mostly its the fuse
Posted on Jul 17, 2008
projdoc
  • 2237 Answers
SOURCE: sony vpl-es1 gets power but will not turn on
if it will turn on with the remote, the buttons arent working. if it doesn't, you have a main board problem.
Posted on Sep 11, 2009
  • 130 Answers
SOURCE: I have a Sony color
hi
your problem is kind of general type it could go from a fuse to important components
it would need much more investigation
Posted on Sep 29, 2010
The light won't go on and there is no power going though the tv
Have you checked your fuse box for a tripped breaker? Resetting
breakers usually does the trick. The breaker box is usually in the basement or garage. If not, check your closets.
Apr 09, 2013 | Televison & Video
Panasonic TH-P50X50Z tv has no power after turning off mains switch then turning back on again
ive had this issue many times since buying my same model tv..i leave unplugged for 3-4 days..plug bk in and usually sweet to go again..
Nov 24, 2012 | Televison & Video
My back automatic window went down and now won't come back up. No sound from motor. Checked fuses. Even took back seat apart but don't know what to do or what caused it. How can I get window to go...
it may need to be reset.
SECTION 501-11: Glass, Frames and Mechanisms 2001 Explorer Sport/Sport-Trac Workshop Manual
GENERAL PROCEDURES Rear Window Motor Initialization s1r~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure that no obstructions are present in the power rear window system when carrying out this procedure.
NOTE: This procedure must be carried out when repairs are performed on any part of the power rear window system including when: the power rear window motor is removed from the window regulator drum housing, a new power rear motor is installed, a new power rear window regulator is installed, a new power rear window module is installed, and any operation in which grease or lubricants are applied to the power rear window system.
NOTE: All power rear window components (window glass module, window regulator, window motor, and glass runs) must be installed and torqued to specification before carrying out this procedure.
NOTE: Steps 1-6 must be completed within 30 seconds. The entire procedure must be completed within five minutes.
NOTE: Once the ignition key is turned to the ON position in Step 6, it must remain on until the entire procedure is completed.
NOTE: Steps 7 and 9 require that the power rear window control switch be held in the closed position until the power rear window motor stalls the window in the upper header seal. Step 8 requires that the window control switch be momentarily turned to the open position.
  1. Start with the ignition in the OFF position.
  1. Turn the ignition to the ON position.
  1. Press the power rear window control switch vent button six times.
  1. Turn the ignition to the OFF position.
  1. Turn the ignition to the ON position. The power rear window will move up-down-up-down approximately 20 mm (0.8 in). This movement indicates that the power rear window motor has entered initialized mode.
  1. Rotate and hold the power rear window control switch to the closed position until the window stalls in the upper header seal.
  1. Momentarily rotate the power rear window control switch to the open position and release. The power rear window will carry out a one-touch down operation until the window stalls at the bottom of the travel stop designed into the window regulator.
  1. Rotate and hold the power rear window control switch to the closed position until the window stalls into the upper header seal. Once this operation is complete, the window will move up-down-up-down approximately 20 mm (0.8 in). This movement indicates that the power rear window motor has been successfully initialized.
  1. Verify correct operation of the power rear window by moving the window to the fully open, vent, then fully closed positions.
  • The power rear window is inoperative (Explorer Sport Trac only)
  • Circuitry.
  • Battery Junction Box (BJB) fuse 3 (30A).
  • Central Junction Box (CJB) fuse 20 (7.5A).
  • Power rear window control switch.
  • Rear window glass motor.
  • Go To Pinpoint Test K .
Sep 15, 2011 | 2001 Ford Explorer Sport Trac
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
Sky + box keeps going into standby mode (turning its self off) and programs dont record or cant be cleared off the planner
Reset your Sky Box. That fixes 98% of all problems, disconnect from power reset, button at rear usually. Power back up, this may just fix your problem. Otherwise, get the Sky unit replaced.
Mar 29, 2010 | Televison & Video
Two MC50's that won't turn on.
The display connector on these devices are pretty poor they can come loose very easily even with the addition of tape from Symbol.
Also seen the power supply cable get pinched when not routed correctly, broken battery pins, faulty power and reset buttons.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
May 22, 2009 | Acer N300 Pocket PC
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
Black Lines
Just to reset first before proceed another procedure;
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet for 4 - 6 hours.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Oct 07, 2008 | Hitachi 61SWX10B 61" Rear Projection...
Black Spots
Resetting the TV
NOTE:
1. Unplug the TV power cord from the power outlet.
7. Turn on the TV.
Regards,
VOTIT
Sep 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
Sony Ta-sa200wr S-air Surround Amplifier Ezw-rt10a Wireless Transmitter Logo
48 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
