Question about RCA Tablets & eReaders
RCA Tablet rct6378w2 wont charge up and hold a charge.
You can plug it into the charger, tried more than 1 and it won't charge up no matter how long you have it plugged in.
    Problem Solver:
  • 25 Answers
Try ordering a new charger, if that doesn't work, it may be that your charging port has loosen or damaged, have someone checkl it, luckily the parts are available on ebay, just make sure to put in the exact model number when looking.
Posted on Jun 13, 2014
SOURCE: no power
I had the same problem! It's not your charger, it's the tablet.
Most likely, the soddering came apart on the inside of the tablet, on the part that connects the charging port with some important wires. You can either take the cover off and fix it, but if it's like mine, it'll just come apart again.
This is what i did: plug in the tablet, and cross the cord from the right across the screen, to the left, and make sure it's tight. I use a binder clip to make sure it stays and charges.
Now try powering it up....that should work :)
Posted on Dec 13, 2012
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Posted on Sep 17, 2011
bad_habit_bo
SOURCE: my sylvania tablet will not charge or power on, i've tried the hard reset and it didnt work do you think that the charger is bad or thetablet is defective
(will not charge or power on)I sent my smartphone in for repair the other day.They told me it was water damage in the charging point
i have never had it near water but apparently having the phone in high humidity places is common for it to happen eg talking on phone under bus stop in the rain, having phone somewhere in bathroom while having shower,
holding phone over hot coffee? hope you get it fixed :p
Posted on Jul 29, 2012
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
leighp123
  • 1669 Answers
SOURCE: tablet won't charge
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Posted on Jan 02, 2013
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
My Kindle will not charge
Here's a possibility, I just plugged in my Kindle Paperwhite using the Kindle charger and USB cable. It wouldn't charge.
I kept it plugged in all afternoon and it accepted no charge although it showed the little lightning bolt on the icon suggesting it was charging.
I unplugged the charger (it has two prongs) and reversed it so
the logo was on top and, Lo and Behold it charged. It could be the plug is not omniidirectional (i.e. it is polarized)
Feb 14, 2015 | Amazon Kindle Paperwhite
My nextbook 7 will not charge. When I plug in the charger it would begin to charge for a dew seconds and then the charge will drop. I thought that maybe it was the charger, so I tried the charger on...
Is there an indicator light that comes on when the charger is plugged in. If so, does it stay on. If there is and it does then there may be a problem with the battery. If there is a light but it goes off when you wiggle the plug when it's plugged in, then there may be a broken connection inside where the charger plugs in to the socket.
Jan 02, 2015 | Tablets & eReaders
How do i tell if my zeki tablet has a dead battery
I think you answered your own question. If you get a charging indication when plugged in and it stays on only while plugged in, that mean the internal power supply is accepting the charger power and trying to charge the battery but your battery is toast and will need to be replaced. The same principle would apply for any laptop or smartphone for that matter.
Dec 05, 2014 | Tablets & eReaders
Won t turn on
Have you held the button in for ten seconds? Are you pushing it in correctly? Did you charge it? If the battery goes down it will not come on. Plug in the charger for awhile then try turning it on. If you spilled something on it you might have a problem. So many things we dont know. Try the charger first.
Sep 05, 2014 | Amazon Kindle Fire HD
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Kindle does not charge properly
Let's try to reset the charger system.
Step 1: Unplug from the charger, press and hold the Power button for 30 seconds
Step 2: Plug into the charger. Press and hold the power button for 30 seconds
Step 3: Let charge for 12 hours
Step 4: Unplug form the Charger, run the Kindle until totally dead.
Step 5: When DEAD. Press and hold the power button for 60 seconds.
Step 6: Plug into the charger, let charge normally
If this does not reset the charging system you have either a faulty Kindle or a faulty charger, contact Amazon for replacement.
Apr 01, 2013 | Amazon Kindle Fire HD
M975 won't turn back on
I had the same problem before, it may need to charge but, your charger might be fried from having it plugged in too long... purchase or find a new charger for your product
Mar 22, 2013 | 7 inch Black M975 Android 4.0 Tablet PC...
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
Pandigital will not start up
1. Is there voltage from charger to plug (Volt Meter Needed) 2. Has unit been dropped or wet 3. How long has unit been down?
Jul 09, 2011 | PANDIGITAL Digital Book 843967071153...
Tablets & eReaders Logo
870 people viewed this question
Top RCA Tablets & eReaders Experts
Ron Dufek
Ron Dufek
ccsi99
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
