Question about Freezers
Manual bosch model GSD3201GB is it frost free
Ocean Frost Free dial keeps going inro Red/Black & we have no Manual
Hi clarry441,
I would like to clarify if what is the brand, type and model name of your unit?
Thank you for using FixYa.
Jun 27, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hi, I have a Bosch Logixx Fridge/Freezer (frost free), works fine apart from large build up of ice on floor of freezer which I constantly have to remove. Any ideas? Many thanks Peter
Hello
check that it defrost elements (heater elements) are working if they working then check if the sensor is working and if the door is sealing when its closed or if the drain is open.
Thanks
Jun 04, 2011 | Freezers
Is this freezer manual defrost or frost free?
Well, it would have helped had you included the actual model number, but without that, if you have a fan that blows air from the freezer into the fresh food compartement, its an automatic defrost design, A.K.A frost free.
Oct 02, 2010 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Is a Kenmore upright freezer model 253.23424102 frost free?
No it is not frost free. You can get the manual on the link below to read about the freezer and learn how to defrost.
http://www.managemylife.com/mmh/owner_manuals/134/KENMORE-Upright-Freezer-L0307021?brand_name_search=253.23424102+
Good Luck and please rate 4 thumbs up for the free answer.
Jul 26, 2010 | Kenmore Freezers
Ice built up in the frost free freezer section
It sounds like the freezer fan(evaporator) is wearing out. This problem is very hard to diagnose because the fan spins but no fast enough to circulated the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Freezers
Temp not going below zero
If that is 0 F it is probably the default temperture and is ok. Above 0 food detoriates quicker and below you get freezer burn faster.
If the controls are locked to that temperature it usually involves holding the button for 3 to 5 seconds to unlock and then adjust. (That is on modern frost free freezers in general)
May 04, 2009 | Bosch Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Freezers Logo
64 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
