Question about Health & Beauty
Scherna spares looking for adaptor
Cone filter without a crank case ventilator adaptor
If you try a speed shop spares you may find an adaptor for this update . I would check very carefully the micro particle rating of the cone filter and if it is bigger particle than the original air filter I would bin it as it will damage the motor from dust that will get through it.. Looks "smick" but some are not practical
Apr 08, 2014 | 2009 Dodge Charger
HP Desktop Modem broken ethernet port
Try to load the latest driver, you can get that from HP under your computer. If that does not fix it then go buy a cheap USB Ethernet adaptor from Amazon or BestBuy, plug it in to a spare USB port and follow the directions for the adaptor with your Ethernet cable plugged into the new adaptor.
That is it, you have bypassed the bad Ethernet power and can forget about it (they can't be fixed), you should be good to go.
If you don't want to try the driver, then just get a new adaptor and that will bypass the internal adaptor.
Good Luck
Mar 15, 2014 | HP Computers & Internet
I need a new AC adaptor, im living in australia, can you help DC5.7V , 1.2A
Hello
This type of adaptor can be bought from most of the electronic spare part shops in Australia. You haven't specified the AC line voltage of Austalia. Anyway, you can get it from there. OK.
Mar 12, 2011 | Audio Players & Recorders
Dear People I have a Woolworths Elevation cappuccino/ expresso maker its the best I have ever had except the threaded plastic adaptor that connests and holds the steam nozzle to the boiler has broken and I...
how old is it
Woolworth have a shop warranty exchange policy if under 12 months old
look on the bottom on the compliance plate and there will be a country of manufacture and maker
Nov 05, 2017 | Mr. Coffee 072179228578 12 Cup Coffee...
My v2000 will not come on at all? I have it plugged in with the adapter and it's like there is no power to it at all?
check power supply adaptor and batteries if they are supplying enough power, if you can borrow a power adaptor and spare battery try replacing them with one your notebook has.
if it works then your adaptor and batter are out, normaly if the adaptor stops working the battery would have died down too as you would have not noted till the notebook totally died down.
Dec 07, 2009 | HP Compaq Presario V2000 Notebook
My psp will not charge the battery but in my brother it does? After the battery is charged i can use my psp like normal but i hate waiting for the battery to charge before i can continue playing the game....
check your devce with his adaptor. If it is charging, get a spare adaptor. If it is not, probably the adaptor jack on your device is damaged or got unsoldered.
Nov 08, 2009 | Sony PlayStation Portable (PSP) Console
Scanning slides
Any adapter with the similar output and input capability should work
Oct 05, 2009 | Lexmark X7350 All-In-One Printer
I need a new power lead with tmc for a garmin nuvi660 fm. Where do I get one from?
I went to halford, the young man there looked in their spare part box and found me the missing bit in the cigaret light adaptor..
Sep 19, 2008 | Audio Players & Recorders
Health & Beauty Logo
22 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
