Question about GE Cg 9808se Hq Vhs Movie Video System Camcorder Loaded W/ Remote Bundle Man
Older GE newvicon (1CVC5036E) CLR VID VHS CAM- 10 PIN CON- what kind of power supply is needed ? (have none at present)
10 pin connection what kind of power soucre do i need ?
3 Suggested Answers
map9966
  • 2351 Answers
SOURCE: I need a schematic (pin-out)of the MX4-ge
You can download the manual for you're AOpen MX4GE motherboard from the link provided below; ftp://ftp.aopen.com/pub/manual/mb/mx4ge/mx4ge-ol-e.pdf
You'll need Adobe reader installed to view the *.pdf file above.
Download Adobe @ http://www.adobe.com/products/reader/
Open manual to page 33. Here you'll see the layout for the front panel motherboard pins. The view towards the left shows where to connect the jumpers coming from the case to the motherboard. The view on the right shows where each positive wire and negative wire connects. The common colored wire for each jumper will be used as negative. Except for the internal speaker 4-pin jumper. Normally positive wire is red in color and ground is black in color and connects to pins 16 and 19 only. Pin 1 is shown. Pin 2 is to the right of pin 1. Pin three is below pin 1 ECT.
Cheers'
Mike
Posted on Mar 03, 2010
  • 107 Answers
SOURCE: GE GSB22HCPAWW
Usually the tech sheet is inside the control console. Just remove two screws.
Posted on Sep 21, 2011
Is there a protection mode for this lcd visio tv that can be removed for this tv to come on ?
Hello Donald the first thing I would like to Know what the model number of your TV is. But that's ok if you have a external power supply you could try this .Make Shure your TV is not pug In to the Ac outlet. We are going to see if you have a short or a load on your 12v line. Ok you wont to unplug the 12v source from the power supply board. Fine out what pin is the 12v's. Connect your external power source to that pin, apply the 12v and see if it is drawing to much current. If so check the boards for any very hot items. If you have a problem on the 12v line. This will find the part that is loading it down. This is the old way of finding a load on a power source. I hope this will help some. P.S make Shure there is no AC connect to the TV as you do this test and you have the plug off of the power supply board before using the external power source.
Jan 01, 2015 | Televison & Video
Pin out for a dell PS-5201-8D2 power supply
Use caution, some older Dell machines used a non standard, proprietary pin-out on the 20 pin connector ALso the 6 pin is suspect. If you connect a regular ATX PSU, you will fry the MoBo. Look here
DELL ATX motherboard Power Supply pinout
Jan 23, 2013 | Dell (PS-5201-8D2) (PS52018D2) 200-Watt...
It won't get to temp, then it beeps and it says f9...it continues to beep, and inside light is off
Disconnect power to the oven.
Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
Contact a certified GE appliance repair facility if the source of the F9 code has not been discovered. Troubleshooting the oven with the electric power turned on is a job for a certified technician.
Mar 05, 2010 | GE Monogram® ZET3038 Dual Single Oven
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
I do not know how to hook up my goldstar to my TV. My daughter gave me the dvd/vhs that was hers. Are there instructions?
The power cord of the DVD to be connected to the power supply.
the audio cable goes from the audio pin from the DVD player to the TV audio pin.
The video cable goes from the video pin from the DVD player to the TV video pin.
Jul 05, 2009 | Goldstar GBV241 DVD Player/VCR
No vid output
What type of power supply do you have connected to it? The board may require a 24 pin connector plus a 4 pin secondary to power up the board properly. Try upgrading the power supply (at least 500 watts). Check the manual to your board for the power specs.
Mar 17, 2009 | Computers & Internet
Aspire t-180 4-pin power plug
Your aspire does not include a PCI-Express power connector... that's why you'll need to buy an adapter cable that transforms two other type of connectors (molex) available from your power supply into the one you need to feed power to your video card.
You may need a cable like this...
http://shop4.frys.com/product/4734999?
Jan 10, 2009 | Acer Aspireā„¢ T180 PC Desktop
Magnavox VR8280BK01 Newvicon Color Video Camera won't power up!
Janis,
The newvicon tube in the camera probably burned out from nonuse and age. I have several of these cameras and tubes. Would you be interested in selling? Email me at: terolar@cs.com
Aug 20, 2008 | Video Cameras
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
GE Cg 9808se Hq Vhs Movie Video System Camcorder Loaded W/ Remote Bundle Man Logo
61 people viewed this question
Top GE Video Cameras Experts
Ravi
Tony Parsons
Tony Parsons
Are you a GE Video Camera Expert? Answer questions, earn points and help others
