Question about MSI 845E Max2 LR Motherboard
Having problem with power leds on motherboard Please help!!!
Hi, all
Can someone help me connect the power leds please. e-mail is light_hammer@hotmail.com. really urgent!!!
Cheers
  • MrSkittle Nov 14, 2007
    I dont know where to connect the motherboard and i dont have the manual for it
    Problem Solver:
  • 14 Answers
If you've got the manual goto Chapter 2 page 39 for the arrangement diagram, if your power led is a three pin spacing design use JFP2 otherwise use JFP1, just incase you didn't know pin one is the one with the arrow above it on the back of the plug, the diagram will show you the order, if you don't have the manual you can download it as well as all other updated software and drivers here:
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=487
you will need Adobe Acrobat reader which can be downloaded Here:
http://www.adobe.com/products/acrobat/readstep2.html
and if your version of windows is below XP you will need a unzip program eg.Winrar that is downloadable Here:
http://www.rarlab.com/rar/wrar371.exe
It's only trial software but it will get the job done, hope this has helped you.
Posted on Nov 01, 2007
I dont know how to fix the Front Panel Audio Connector. And I dont understand what is ATX power switches. I'll tell you what wire i have: H.D.D. LED, POWER LED +, POWER LED -, RESET SW and POWER SW....
Hi!
You have to make make the four Front Panel Connection as shown below: -
(IDE LED is the same as HDD LED and Ground means negative '-')
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 31, 2011 | ASUS P4VP-MX Motherboard
I had a friend transfer my computer components eg. motherboard, HDD, Ram etc, from a ugly computer case to a nice looking one, she got as far as screwing in the motherboard and hooking the HDD...
Hi:
To solve your puzzle, you need to find the manual for your motherboard. If you don't have it still, almost all of them are available online at the manufacturer's support website. The manual always has the pin out diagram for the motherboard, and from there its just a matter of plugging the small connections together. Remember that connections for LED lights have polarity, meaning that they need hooked up one particular direction for the light to work, but any switch connection doesnt matter.
Hope this helps
Oct 22, 2010 | Computers & Internet
I have a PLE01 mother board and i need to plug in the hdd,ldd and ect plugs and i don't know how they go as i do not have the manual and cannot read the small print can u help
Today's motherboard are easy to setup because mostly are now color coded like those connection ports.All you have to do is place the cables according to their color coded ports. Connectors are easy to identified because they are also labeled with name. Like the picture below.
Connections ports on the motherboard are also labeled similar to the connector cables above or have a similar abbreviated names like PSW for Power SW.
I hope this could help you..
Please don't forget to rate. Thanks..
Mar 24, 2010 | Intel Motherboard
Bluford E139765 mainboard power panel connector
Look at the board really close you'll see it at the bottom right corner, SPKR, RSW, PSW, and so on, try one at a time, until you get it
Jul 16, 2009 | Computers & Internet
How to connect my led lights[that is the red nd green light ] with my 865 chipset''......where r those pins on the motherboard ??
in *********** board where the reset & power botton is connected same place you can find HDD LED for Harddisk and Power LED for power, please be carefull with the sign designation about (+) and (-) it is indicated in the board and pin.
Jun 12, 2009 | EliteGroup ECS 865PE-A7 Intel 865PE...
MotherBoard won't power on (Could be LED placement issue)
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Good luck and thanks for using FixYa!!
May 21, 2009 | Intel Motherboard
Ga-8sr533 hdd led not working
May be , you didn't connect the connector of ur LED on motherboard.
or it's not connected properly.Please refer motherboard manual for the same.
Thanks,
Mukund
May 15, 2009 | Gigabyte GA-8SR533 Motherboard
Looking for a manual for the motherboard p4v533-mx
If you go to the below listed site, you can download the manual for *********** board. To get to it, on the drop down menu, you will select: Motherboard, Socket 478, and P4V533-MX
http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 23, 2009 | ASUS S478 VIA P4V533-MX Motherboard
Front panel connectors
hi im wesley. ok the power and audio connecters is very simple if you look at the bottom right of the motherboard you will see you can plud them and it says the name of witch is the power and witch is audio and it doesnt realy make a difference witch way you put them in just as long as they are on the right pins. the usb might be a little more tricky unless it says witch connecter is the usb 1&2 then its the same as the power led but if you dont come right i will try to get a diagram for you or draw one up but it might not be as accurate tho as i do not own a asus motherboard but i will do my best.
Jul 11, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
How to connect a power in motherboard?
Hi zarathoustra, still have your manual? Go to page 25.
As shown here.
26b4ba3.jpg Little fuzzy.
Need your manual, click this link.
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000010
Suggest you save the link.
Good Day!
Mike
Apr 03, 2008 | Foxconn 865A01-PE-6EKRS Motherboard
MSI 845E Max2 LR Motherboard Logo
109 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
