Question about Sharp CD-SW330 Shelf System
Sharp cd dh 790n no power
No power on
Register to facebook
My advice is don't. It will end badly
Aug 16, 2014 | Other 10X RT8207AGQW DH=BK DH=BJ DH=BH...
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Looking for a manual for Meade 114 EQ-DH. Also looking for the CD that comes with the telescope.
Look under 4.5 inch Reflector on Meade's manual web site:
http://www.meade.com/manuals/index.html
You do not need the CD -- the software on the CD is located on Meade's web site for free download-- here:
http://www.meade.com/support/AutostarSuiteWebEdition55.exe
Sep 02, 2011 | Meade Infinity 114EQ-DH Telescope
Do you have a user manual for a Sharp Micro HiFi XL DH 259 for downloading?
http://www.sharpusa.com/CustomerSupport/search.aspx?q=xldh259n%20operation%20manual
Jun 01, 2011 | Sharp Audio Players & Recorders
How and where do I connect the canon mp830 multifunctional printer to my hp 790n computer
I will assume you have a CD for your printer. Note that there are 4 USB ports on your computer...2 in front and 2 in the back. You will need a standard USB cable no longer than 10 ft. (3M) One end is more square (printer end) and one is rectangular (computer end).
First you need to power up your printer and make sure the printhead and ink is installed and alignment has been done. Then turn the printer OFF. Run the installation software from the CD. At one point you will get a Printer Connection window. Connect the USB cable to both the computer and the printer. You can use either the front or rear USB ports on your computer, whichever is easier to access. Turn the printer ON. The software should recognize the printer and complete the installation.
Here are some important support links for your hardware.
HP 790n Support
Canon MP830 Support
Thanks for using Fixya.
Oct 08, 2009 | Canon Office Equipment & Supplies
My Canon P23-DH calculator is printing out weird symbols
I also have a Canon P23-DH 111 that is printing strange symbols. This has happened after an electrical storm.
I contacted Canon Support and they verified that the board inside has been corrupted by a power surge.
I now have a new Canon P23-DH V and I invested in a surge protector.
My grandaughter is playing with the old machine.
Mar 09, 2009 | Canon P23-DH Calculator
Set time & date on Cannon P100-DH II
I can't help you with the Canon, but for the Sharp see the instructions in the first column of the first page of this manual: http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1750PIII.pdf
Apr 08, 2008 | Sharp EL-1750PIII Calculator
Sharp CD-SW330 Shelf System Logo
41 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
