Question about Simplehuman Office Equipment & Supplies
Simplehuman sensor can lid not working
Lid is stuck and red light is on
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Lid of filter section stucked in Hoover Vaccum Cleaner Model UH70115
Hi Bharat! In the front of the dirt cup near the top there is a red Hoover emblem that is also a latch to open the dirt cup lid. Pull on dirt cup latch to open lid. Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
Wont start
it seems that the lock is stuck or broke. Try to see if u can move it by hand. if not u may need to remove the switch while doing this make sure the wires were connected and not loose. your ? does not say the type of washer u have. mine is a whirlpool deut and I took off kick panel on front bottom of washer and was able to reach the switch when I replaced mine. u can get a new switch at applianceparts.com
Apr 10, 2014 | Washing Machines
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
May 30, 2012 | Maytag Washing Machines
Light keeps flashing on top of canister of my Hoover Wind Tunnel but I emptied and cleaned it well. It sounds right when I turn it on then it goes into this sound like something is stuck but there...
sounds like a possible plug ,then when you first start it up the plug gets stuck a gain.
try taking hose off the unit and running water through hose .if water flows good ,check and see if lid is secure when closed.
Jul 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
I own the Saeco Vienna Superautomatica which I have enjoyed tremendously!!! Unfortunately I made a cup of coffee yesterday and heard a "clunk" then the red light came on. I turned off the machine and...
You have not mention anything about the group. Did you try to take it out and put back again. If the problem insist this mean from your description that the clunk is from group motor gears or even the motor gear it self.
In this case the machine must be desasemble in order to find out which part brocken.
If you can remove group and put back again and nothing happents then switch it of and proceed as above since it might just one gear and by replace it the machine will be ok again. However if you try something more then their is a chance to burn the motor also and the cost for repairing it will high and it will be better to thing about a replacement since spare parts are very high compare to a complete machine that might get it from special offers.
You revice all above and if you need any further asistant you can coment back.
ood luck
Sep 02, 2010 | Saeco Vienna SuperAutomatica Coffee...
Odea go dumps shot
Try this remove the brew unit and clean the screen, the red light is saying that it cannot push water through.
Jul 04, 2009 | Saeco Odea Go
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Top Simplehuman Office Equipment & Supplies Experts
k24674
Are you a Simplehuman Office Equipment and Supply Expert? Answer questions, earn points and help others
