Question about Canon SELPHY CP710 Thermal Photo Printer
Botton half doesnt print
Bottom half of the picture doesn't print
Why does my cannon cp-200 printer only print half the image already changed ink cassette
it is probably set to print a certine size of the photo, can you do a print preview before printing and see what that looks like, then check all your print settings.
Sep 13, 2014 | Canon Office Equipment & Supplies
When printing, it doesn't print the full detail. It prints, but has lines missing from it to make it un readable. Like if I were to print a letter the top half of the sentence would print but the...
it could be the coagulation of ink in between the cartridge better dip it in mild hot water for some times and replace it wiping the water . it would do the trick and solve your problem . it has been practically tested.
If this solution helpful/useful for you please rate my solution.THANKS FOR USING FIXYA.
May 16, 2011 | Epson stylus nx110 All-In-One InkJet...
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Bottom half of picture is printing
I had the same problem. There is a rod that on one end has a plastic gear and cam mechanism, and on the other end is a plastic cam. This rod rotates and pushes the print head against the paper. On my unit the plastic cam (not the one with the gear) split and was not putting pressure on the head on what would be the top half of the picture. I determined the proper position for the cam and super glued it in place. Now it is working like new.
Jun 19, 2008 | Kodak Dock Series 3 Laser Photo Printer
HP 920 Fax Half Lines
Try making a copy of something.
If the copy comes out the same way as your faxes, then the ink cartridge is either dirty or clogged.
You can try removing the cartridge and checking the bottom of it.
You can even wipe the bottom of the cartridge with some denatured alcohol.
If this doesnt work, then purchase a new cartridge and your problem should be solved.
Good luck.
Hope this helps.
Mac =)
Apr 02, 2008 | HP 920 Plain Paper Fax
Only half of picture is printing
I have the same problem where only the bottom half of my photo prints. It worked fine for a long time. I even tried flashing the printer up to the 2.11 firmware version from 1.90 - still nothing. Changed paper and cartridge. NOTHING. Tried attaching it to both my PC & MAC and even print stand alone picture from camera and a SD memory card on the side. NOTHING.
I think the problem is with Kodak... My trouble started when I decided to move my Dock Printer from PC over to MAC. The new drivers have you flash the Firmware. To do this, you first must hold down the Print and Red EYe Button (The button directly to the right of the big print button) with the power cord unplugged and then plug it in holding the buttons in for 2 seconds afterward.
This put the printer into Edit mode and allows the firmware to upgrade the printer. Once I did that, THAT'S when my problem started. I think these crappy printers can NOT self calibrate and they must be factory set. Most likely, they need to do it at the factory themselves and are all to happy to charge you to ship it off and do it for you.
THANKS KODAK!
What a POS.
Mar 20, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
BLANK
there is a ribbon connector between the bottom half and the top half of your phone, this carries all the information for the top half ie picture & sound etc. It is more than likely that this cable is damaged someway. you would need to disassemble the phone and check the plastic ribbon carefully to be sure.
Jul 02, 2007 | LG PM-225 Cellular Phone
Canon SELPHY CP710 Thermal Photo Printer Logo
old marine
old marine
