Question about Scott Archery Scott Little Goose Release 3002S
Tighten release adjust release tension
What adjustment do you need to make when the bobbin is throwing too much thread out.
Your tension is is too loose somewhere I guess, so will need tightening. Tighten the upper tension first to see if that helps before tackling the spring on the bobbin. If you need to tighten the spring on the bobbin then do it in tiny increments and remember where you started. Try taking out the bobbin and gently pulling by hand the thread from it; it should have a slightly tight feel on the correct tension..
Oct 01, 2015 | Sewing Machines
How do i tighten the timing belt tension on a 1999 dodge stratus
The belt tensioner is not adjustable. To loosen a tensioner you would swivel the belt tensioner away from the belt with a long flex wrench or ratchet and to tighten the belt you would let the spring in the tensioner move the swivel back into the tight position. An internal spring tightens the tensioner pulley against the belt. You will need to get a smaller belt or replace the tensioner if the belt is "too loose" after you swivel it back into the tight position against the belt and release pressure.
Oct 19, 2012 | 1999 Dodge Stratus
How do I replace the serpentine belt on a 1994 concorde?
Remove the alternator/power steering pump and water pump drive belt to gain access to the air conditioning drive belt.
To remove and install the air conditioning compressor drive belt, first loosen the tensioner pulley lock nut, then turn the adjusting screw to raise or lower the tensioner pulley assembly Accessory Drive - 3.3L Engine or Accessory Drive - 3.5L Engine To adjust the air conditioning drive belt, loosen the tensioner pulley nut and adjust belt tension by tightening adjusting screw. Torque pulley nut to 54 N•m (40 ft. lbs.) after adjustment.
The Poly-V generator/power steering belt has an adjustable tensioner pulley located on the timing belt cover Accessory Drive - 3.5L Engine to maintain proper belt tension. To remove or install this belt, Release tension by loosening the tensioner pulley nut and adjustment bolt Accessory Drive - 3.5L Engine Reverse procedure to install and tighten belt to specified tension.
Jul 10, 2012 | 1994 Chrysler Concorde
How to remove alternator on a 2005 range rover
Hi
Click here
the link above should tell you all you need to know if you get stuck or have any problems give me a shout back ok
Oct 26, 2010 | Land Rover Range Rover Cars & Trucks
I want to change two belts (A/C and Alternator) on my 1999 Mitsubishi Mirage 1.5 car. What steps I am suppose to do.
First, feel the tightness of your belts. You will have to tighten the new belts to the proper tightness. If they are too tight, they will wear the bearings prematurely. If they are too loose, they will slip.
Alternator Belt Removal
  1. Loosen the alternator lock nut.
  2. Loosen the adjuster bolt.
  3. Rotate the adjuster bolt counter clockwise to release the tension on the belt.
  4. Remove the belt.
Similarly for the compressor belt
  1. Loosen the lock nut.
  4. Remove the belt.
5. Install the new compressor belt
6. Rotate the adjuster bolt clockwise until the belt is tight like it was before you removed it.
7. Tighten the lock bolt.
8. Install the new alternator belt
9. Rotate the adjuster bolt clockwise until the belt is tight like it was before you removed it.
10. Tighten the lock bolt.
11. enjoy life
Oct 12, 2010 | 1999 Mitsubishi Mirage
Belt routing for 2000 ford escourt
The belt routing is often found on a sticker, under the hood. But, the best I can do is instructions on how to change the belts, step by step:
REMOVAL & INSTALLATION 1.8L Engines ALTERNATOR AND WATER PUMP BELT
  1. Riase the front of the car and support it with safety stands.
  2. Loosen the alternator adjusting bolt.
  3. If necessary, remove the power steering drive belt .
  4. Loosen the alternator mounting bolt.
  5. Remove the alternator and water pump drive belt. To install:
  6. Install the alternator and water pump drive belt.
  7. Adjust the belt tension.
  8. If removed, install the power steering pump belt.
  9. Tighten the alternator adjusting bolt to 14–19 ft. lbs. (19–25 Nm).
  10. Tighten the alternator mounting bolt to 27–38 ft. lbs. (37–52 Nm).
  11. Lower the vehicle.
POWER STEERING PUMP BELT
  1. Raise and safely support the vehicle.
  2. Loosen the power steering pump mounting bolt and nuts.
  3. Remove the drive belt. To install:
  4. Install the belt and adjust the tension.
  5. Tighten the power steering pump mounting nut, located near the adjusting bolt, to 27–38 ft. lbs. (37–52 Nm).
  6. Tighten the pump mounting bolt behind the pulley to 27–40 ft. lbs. (36–54 Nm), and the remaining pump mounting nut to 23–34 ft. lbs. (31–46 Nm).
  7. Lower the vehicle.
1.9L and 2.0L SOHC Engines
  1. Insert a 3?8 in. drive ratchet or a breaker bar in the hole on the automatic tensioner, then pull the tool toward the front of the vehicle.
  2. While releasing the belt tension, remove the drive belt from the tensioner pulley and slip it off the remaining accessory pulleys. Fig. 1: Insert a 3?8 in. drive ratchet or breaker bar into the hole of the automatic tensioner 90981p74.jpg
    Fig. 2: Pull the breaker bar or ratchet toward the front of the vehicle to relieve belt tension 90981p75.jpg
    Fig. 3: Once the tension has been released, remove the belt from the pulleys and the vehicle 90981p76.jpg
    To install:
  3. Position the drive belt over the accessory pulleys.
  4. Insert the 3?8 in. drive ratchet or breaker bar into the hole of the automatic tensioner, then pull the tool toward the front of the vehicle.
  5. While holding the tool in this position, slip the drive belt behind the tensioner pulley and release the tool.
  6. Remove the tool from the automatic tensioner.
  7. Check that all V-grooves make proper contact with the pulley.
2.0L DOHC Engines
  1. Raise the car and safely support it with jackstands.
  2. Use a 13mm wrench to rotate the tensioner clockwise.
  3. Remove the drive belt from the pulleys. To install:
  4. Position the belt on the pulleys.
  5. Use a 13mm wrench to rotate the tensioner clockwise.
  6. Route the belt as shown in the illustration and release the tensioner.
  7. Lower the car.
  8. Run the engine for a few minutes to seat the belt in the pulley grooves.
Sep 03, 2010 | Ford Escort Cars & Trucks
How to loosen tension release for fan-belt replacement
You may need that tool I cant think of the correct name rigth now but usually its leftie loose righty tighty! How doesw your tension release look?
Jan 15, 2010 | 2001 Jeep Grand Cherokee
Need diagram for serpentine belt
2004 SUZUKI FORENZA - L4 2.0L 2000cc GAS FI N
Adjustment
The belt is automatically adjusted by the auto tensioner.
Drive Belt Routings
Fig. Accessory drive belt routing-2.0L engine
Removal & Installation
  1. Remove the air filter housing assembly bolts and the air intake tube.
  2. Remove the air filter housing assembly from the vehicle.
  3. Use a wrench to turn the tensioner bolt clockwise, compressing the tensioner, and releasing the tension on the serpentine accessory drive belt.
  4. Remove the serpentine accessory drive belt.
To install:
  1. Use a wrench to turn the tensioner bolt clockwise, compressing the tensioner, and releasing the tension on the serpentine accessory drive belt.
  2. With the wrench in place on the tensioner bolt, loop the serpentine accessory drive belt loosely over the pulleys.
  3. Slip the belt over the tensioner.
  4. Remove the wrench from the tensioner bolt and the belt will tighten itself.
  5. Install the air filter housing assembly into the vehicle.
  6. Install the air intake tube and the air filter housing assembly bolts.
  7. Tighten the air filter housing assembly bolts to 53 inch lbs. and nm
I really hope helped with this. remember rated this help. Good luck.
Nov 12, 2009 | 2004 Suzuki Forenza
Adjusting Padking Brake with 4 wheel disc brakes.
Hope this helps. This is out of the factory manual. Let me know if this works for you.
PARKING BRAKE NOTE: Tensioner adjustment is only necessary when the tensioner, or a cable has been replaced or disconnected for service. When adjustment is necessary, perform adjustment only as described in the following procedure. This is necessary to avoid faulty park brake operation.
  1. Raise vehicle.
  2. Fully back off cable tensioner adjusting nut at equalizer to create slack in cables.
  3. Remove rear wheel/tire assemblies. Remove brake calipers and rotors.
  4. Verify park brakes are in good condition and operating properly.
  5. Verify park brake cables operate freely and are not binding, or seized.
  6. Check park brake shoe adjustment.
  7. Reinstall rotors and make sure rotors turn freely.
  8. Reinstall brake calipers. Tighten guide pin bolts to 41 n·m (30 ft.lbs.)
  9. Reinstall wheel/tire assemblies after brake shoe adjustment is complete.
  10. Lower vehicle enough for access to park brake foot pedal. Fully apply park brakes
NOTE: Leave park brakes applied until adjustment is complete.
  1. Raise vehicle again.
  2. Mark tensioner rod 6.35 mm (1/4 in.) from edge of tensioner bracket Adjustment Mark On Cable Tensioner Rod
  3. Tighten adjusting nut at equalizer until mark on tensioner rod moves into alignment with tensioner bracket
CAUTION: Do not loosen, or tighten the tensioner adjusting nut for any reason after completing adjustment.
  1. Lower vehicle until rear wheels are 15-20 cm (6-8 in.) off shop floor.
  2. Release park brake foot pedal and verify that rear wheels rotate freely without drag. Verify pedal returns to fully released position.
  3. Lower the vehicle
Mar 09, 2009 | 1999 Chrysler 300M
1994 saab 900 se replacing timing belt
STEP 1 Remove Air Filter. STEP 2 Loosen the bolts securing the crankshaft pulley. Remove the load from the belt tensioner by turning the belt tensioner pulley locking bolt forward in the car using a 15 mm wrench. Remove the belt from the coolant pump pulley and slowly release the belt tensioner. STEP 3 Remove the belt tensioner and remove the steering pump pulley STEP 4 Remove the water pump pulley use the engine bracket to pry against. STEP 5 Remove the timing cover and Remove the right-hand front wheel and the cover in the wheel housing. STEP 6 Remove the crankshaft pulley (undo the six bolts but do not remove the centre bolt). STEP 7 Place the engine top dead center and Zero the engine. The markings on the camshaft sprockets and timing cover should be in alignment as also should the marking on the crankshaft. Use locking tools 83 95 006 and KM-800-2 for the camshaft sprockets and locking tool KM-800-10 for the crankshaft (These tools can be purchased from Saab (18774177222) or from Baum Tools). STEP 8 Before removing the toothed belt mark its direction of rotation . To facilitate refitting the belt can be marked at both the camshaft marking and the crankshaft marking. STE9cc7b85.jpgP 9
STEP 10 Fit the toothed belt according to the marked direction of rotation. Use setting tool 83 95 006 to keep the belt in place and adjust the tensioning roller loosely by hand to prevent the belt from jumping off. Adjust counterclockwise. Fit a section of the toothed belt and fit tool 83 93 985 to measure the belt tension. Loosely tighten the centre bolts of the adjusting rollers. Adjust the lower adjusting roller counter clockwise to a belt tension of 275-300 Nm. Turning torque 30 lb.ft ft ******The adjustment of the belt tension is for preparation ONLY and must not be used as a check when the belt adjusted for the final time! STEP 11 Turn the engine over two revolutions until just before the zero mark and place the locking tool on the crankshaft. Carefully turn the crankshaft in the direction of engine rotation until the arm rests against the coolant pump's flange and then tighten the arm. Fit setting tool 8395006 and check that the markings on the camshaft sprockets are aligned with the markings in the tool. ********Check that the A marking is approximately 2mm above B marking. If the distance is less readjustment is necessary. STEP 12 Fit the crankshaft pulley and Tighten to a torque of 15 foot lbs. STEP 13 Reinstall the inner wheel cover and front right wheel.
STEP 14 Reinstall Timing Cover.
STEP 15 Reinstall the water pump pulley use the engine bracket for leverage. STEP 16 Reinstall the power steering pulley and tighten to 6 foot lbs. STEP 17 Reinstall the belt tensioner and tighten to 30 foot lbs. STEP 18 Remove the belt tensioner load/pressure by turning the belt tensioner pulley locking bolt forwards in the car using a 15 mm wrench. Install the belt on the coolant pump pulley. Carefully release the belt tensioner. STEP 19 Reinstall the Air Cleaner and hoses that accompany Release the belt tension and remove the toothed belt.
Jul 18, 2008 | 1994 Saab 900
Scott Archery Scott Little Goose Release 3002S Logo
499 people viewed this question
Top Scott Archery Hunting Experts
Peter
Peter
Carl Wiehe
Carl Wiehe
Bruce Mommaerts
Bruce Mommaerts
Are you a Scott Archery Hunting Expert? Answer questions, earn points and help others
