Question about Yamaha DTX-MULTI 12 DRUM PAD
Dtx multi 12
Logic pro
Not working, power is on but nothing is coming up in the screen
The embedded software on board is not booting up. It may have detected a hardware problem. Make sure the power supply is in good condition then disconnect everything else and try again. If fault remains, its toast.
Dec 16, 2013 | M-Audio AXIOM PRO 61 MIDI CONTROLLER
How to hook up my Behringer V-amp pro
Hook it up to what? You'll probably want it in the insert on the guitar channel.
Nov 30, 2013 | Behringer V Amp Pro Guitar Multi Effects...
I would like to connect my fantom g6 to logic and be able to play the sounds from logic through my fantom and record into logic.
If you hook it up with the USB cable Logic should recognise it. You may have to select it in the Audio Preferences as your Audio Interface.
Jun 30, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
Mar 09, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
Weak LCD Display on a Yamaha DTX Electronic Drum Kit
NOT a battery issue.
Note that many of these devices have a parameter one can set for "contrast" or "viewing angle". You might want to check your owners manual for this possibility.
I downloaded the DTX manual and there IS a contrast control on the back of the unit near the top left facing the back...
IT MAY require a screwdriver to adjust it.
Apr 03, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Jan 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha DTX-MULTI 12 DRUM PAD Logo
32 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
