Question about Fellowes DM17CS Confetti-Cut Shredder
Shredder is jammed
How do you dismantle the shredder to unjam it?
3 Suggested Answers
  • 35 Answers
SOURCE: jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Posted on Mar 03, 2009
1alexh
  • 484 Answers
SOURCE: mY FELLOWS GD1200 SHREDDER IS REALLY JAMMED WITH
First, UNPLUG IT!
2 - Then remove the top. shredding part and flip it over.
3 - Carefully, with your fingers, not a pliers, remove all the paper bits and pieces from the underside of the shredder.
4 - Turn it back to right side up, and place it on the basket as it should be positioned, then plug it in and turn it on in REVERSE first.
5 - Once it starts, let it run until it stops; it should only be a couple of seconds.
6 - Turn the direction back to normal, and see if it will run that way.
Good luck,
-a.
Posted on Apr 22, 2010
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
My shredder is jammed and I cnnot get unjammed
Hi. Go to the local hardware store and purchase a small pair of needle nosed pliers. Use these to pull the paper from the shredder a little at a time. Then in the future only shred up to 3 sheets at a time so it does not jam on u. J.
Aug 06, 2010 | Royal 160MX Shredder
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
Jammed shredder
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Something is jammed
I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
Jan 08, 2008 | Office Equipment & Supplies
Shredder
Remove as much of the jam as possible then saturate any paper left with shredder oil or you may use any liquid vegetable based cooking oil from your kitchen. After letting paper soak for at least 7hours you should be able to power through the jam. If not call Fellowes customer service at 1-800-945-4545
Nov 27, 2007 | Office Equipment & Supplies
Fellowes DM17CS Confetti-Cut Shredder Logo
46 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
steve morris
steve morris
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
