Question about Mitsubishi WS-65909 65" Rear Projection Television
I am unable to disply my laptop computer screen onto the TV. I laptop displsy adapater recognizes the "2nd" monitor as a 640x480 60 hz monitor, but there is only a blue screen on TV when I chae the devcie on my WS65909 to "Computer" and have a VGA cable plugged in. What can I do to get my PC to display on my TV screen?
    Problem Solver:
  • 5 Answers
You might have faulty cables. they get broken alot, aren't very reliable.
Posted on Jun 14, 2009
Why did my omni 100 disply screen shink, how do I fix it
ATI Radeon HD5450 graphics processing unit (GPU) soldered to the motherboard
Figure 3: GPU with fan
  • Interface: GPU chip soldered onto motherboard
  • Maximum resolution:
    • HDMI TV resolution: up to 1080p at 60 Hz*
    • HDMI PC resolution: 2560x1600 at 60 Hz
    • DVI TV resolution: up to 1080p at 60 Hz*
    • DVI PC resolution: 1920x1200 at 60 Hz
    • VGA resolution: 2048x1536 at 60 Hz
You need to use the ATI Catalyst Control Center software to optimize display.
See this page for the Omni 100 drivers
See HP Support
Aug 27, 2014 | HP Omni 100 PC
Connecting computer to Element flx-3211b via HDMI not working
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
Feb 26, 2013 | Element Electronics FLX-3211B 32 in. LCD...
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
I'm having trouble getting my monitor to recognize my laptop when I hook them up. I tried going to my desktop, then adding a device or projector, then adding the monitor but the tv still won't...
What you'll need to do is set your TV to whatever input you're using on the laptop (VGA or HDMI). Then go into Display Properties, which can be found in Control Panel. Select the grayed out 2nd display and check "Extend desktop onto this monitor". Slide the resolution to something your TV can support such as 1366x768 or 1920x1080. Apply, OK, OK and you're done. The exact steps that you'll need is slightly different than the instructions here because of variation in TVs and OSes, but it's mostly identical.
Aug 19, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
I have a fx5500 card and cannot get it to display on the tv whn i boot up both monitor and tv displsy theboot up but then my desktop shows ok on monitor but the tv is blank, it doesnt dectect the tv at all
well there is a problem with some cards that wont disply on TV and some do but the screen is black n white thats the way it is. its due to the driver, update the driver to latest and then give it a shot.
Dec 19, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
Broken HP pavillion dv7 screen refuses to recognize the remote mo
try connecting another monitor. If it does not find it automatically Hold down the fn key and press the F4 key this will toggle through 3 different modes. main screen only, Mirror main screen on 2nd monitor, or Extend desktop to 2nd monitor.you can set the resolution of each seperately. Right click on desktop and choose proprties or control panel>display
Sep 08, 2009 | HP Pavilion dv6000z Notebook
Red tinge on tv screen when laptop plugged through HDMI
Neo2123 is correct.
The HDMI output is setup as a second disply, not Primary disply.
You will need to get into the video Driver settings and configure this for a single monitor.
1. Right click on the desktop
2. select "graphics properties"
3. set up the "Digital Display"
All the steps or naming may be different on you computer, but some of this is fiarly standard.
May 08, 2009 | Televison & Video
Using my tv as a monitor
Right click on desktop, then go to properties. Click on the settings tab. There should be two boxes, labeled 1 and 2. Click on box 2 and select:
Use the device as the primary monitor and Extend my Windows desktop onto this monitor. Also go to advanced -> Monitor and make sure that the screen refresh rate will not damage your tv. For older tv's it's usually 60 Hz for NTSC and 50 Hz for PAL.
After getting your settings where you want them, click apply. This will transfer all video output to the auxillary screen and will leave your primary monitor blank until you change the settings back to the primary screen.
Oct 25, 2007 | ATI Atlantis RADEON 9000 (128 MB) Graphic...
Mitsubishi WS-65909 65" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
