Question about Varian Cp-3800 Gc Manual
Unstable connection GC and PC
Connection between the computer and GC Varian 3800 during the process of disappearing, our newly installed systems programmer program
Window xp sp1. I have net frame work 3.5 full version. I want to install it to my pc but i donot have internet connection. How to install it Without internet. I try to change language to uk english it...
First you must have the installation disc.
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Nov 20, 2012 | Computers & Internet
Tip
How to Upgrade Windows 98 or Windows Millennium Edition Profiles to Windows XP...
This guide describes how to upgrade a Microsoft Microsoft Windows 98-based, or Microsoft Windows Millennium Edition-based client that has user profiles to a Microsoft Windows XP-based client.
The following steps enable the Windows 98 and Windows Millennium Edition (Me) profiles to be retained throughout the process.
Your best method to retain the profiles is to join the domain during the upgrade installation process.
Otherwise, you must use a workaround method to transfer the profile information over to the Windows XP profile.
During the upgrade installation process, at the networking section, the administrator is offered the choice to join a domain or a workgroup.
If you join the domain at this juncture, you ensure that all the existing profiles are migrated successfully to the Windows XP-based installation.
If you did not join the computer to the domain during the upgrade process, you must use the following workaround method:
Join the upgraded computer to the target domain.
All applicable users must log on and log off (which generates a profile).
Copy the appropriate Application Data folder from the Windows 95, Windows 98, and Windows Me profiles to the newly created user profiles.
on Jul 03, 2010 | Computers & Internet
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
How to connect the microtek scanmaker 3800 to system
Run a search for the scanner software on the internet and download it then install it to your computer. (type in microtek scanmaker 3800 software) Then connect the scanner to your pc and turn it on.
Mar 25, 2012 | Microtek ScanMaker 3800 Flatbed Scanner
My desktop keeps disappearing
Hi!
Remove unnecessary programs installed on your computer. This will help you save space and then more room for special processes for system performance.
Next, I advise you to run a full computer scan. This will help eliminate viruses or spywares on your PC and I think which is also the culprit to your Desktop suddenly dissapearing. Viruses are nasty and they will do everything to bug your computer down.
Sep 10, 2009 | Computers & Internet
Hard Drive Not Recognized
make sure all wire connections are completely pushed in. try going in to the BIOS and see if it reconized it
Mar 11, 2009 | ASUS P5RD1-VM Motherboard
A4tech viewcam pk635M
i want to connect my cam ..
Nov 21, 2008 | A4tech PK5
Installation of JVC USB driver
The JVC USB driver was written before introduction of the Windows XP system. This warning is displayed with other manufacturer’s digital cameras, also, and is not strictly a JVC phenomenon. In order to use the USB interface between the camera and your computer, select the “CONTINUE anyway” option provided in this warning display. To JVC’s knowledge, there are no negative effects to using JVC driver with Windows XP.
Sep 14, 2005 | JVC GC-A33 Digital Camera
Varian Cp-3800 Gc Manual Logo
64 people viewed this question
Top Varian Science & Laboratory Experts
Joseph Vernice
Joseph Vernice
schwaa44
schwaa44
Are you a Varian Science and Laboratory Expert? Answer questions, earn points and help others
