Question about Protron PLTV-32 Television
Ac adapter the tv will not even turn on. I got the adapter checked out and thats what seems to be the problem.
  • 4,102 Answers
These adaptors are hard to buy as they are not a standard connector if you go to a tv repair shop they should be able to order you a new one but get them to check that it is the power lead and that it is not a fuse that has gone because their are fuses inside the telly and if you hacve had a power surge this is useually the problem but before you buy new adaptor check this is a problem cus the adaptors can be expensive where a new fuse can cost less than a fiver hope this is some help you might be able to get adaptor off net
Posted on Oct 30, 2007
I have a Samsung model PN60F5300BF that just died on me. Its barely 2 years old and one day it just went dead as if there is no power to the TV, even the red indicator light does not come on anymore
This may seem silly but you shuold check to be sire the power cable is plugged into the back of the TV, the other end is in a power receptacle, and if it's in a power strip, that that strip it turned on (some have a switch). A breaker might have tripped too. If none of these are correct, see if there's a reset button on the rear of your TV.
Dec 06, 2016 | Samsung PN60F5300BFXZA 60" 1080p 600Hz...
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
Im after a bush ac power adaptor for a LCDS20TV011
You could get one from ebay , but they seem very expensive. (It does say make an offer)
Other models may use the same supply and its cheaper, You could check with the vendor if a cheaper one is suitable for the Bush, after all why pay more for the same thing. You just need to make sure the current/wattage and the plug on the end are the same.
Jan 17, 2011 | Bush 24v Ac Power Adapter For Bush...
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
I have a Toshiba Satellite laptop and it's about 10 years old. That's why I need to plug in to my ac adapter in order to turn it on. But now, even when I have the ac adapter plugged with my laptop, the...
sounds like charger is gone , can you hear a humming noise from your charger when you press it againts your ear, if so it seems ok if not its gone, you can search ebay for a charger and they are very cheap.
hope this helps
Dec 04, 2009 | Toshiba Satellite A105 Notebook
My wii will not turn on, I have never had a problem with it before. I checked all of the plugs and everything seems great except it will not turn on.
It seems every 5th problem I see is this issue. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii or in the Owner's Manual.
This is a common problem with the Wii. It happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens.
Power will come back on, or you'll go to turn the Wii on one day, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 29, 2009 | Nintendo Wii Console
My Sceptre TV doesn't turn on.
Jan 28, 2018 | Dell Dimension 8400 power supply ** FREE...
Wii turned on, but no video output
Just spoke to Nintendo Technical support. Seems the rub is in the AC adapter itself.
Need to power down at both ends of the AC adapter--unplug AC adapter from wall output AS WELL AS from back of Wii.
Wait at least two minutes to allow any charge in the adapter itself to dissapate. Plug adapter into wall first, then back into the Wii, making sure your peripherals (eg AV receiver, TV, projector if using) are already on.
Tech support says sometimes you get a partially tripped "fuse" within the AC adapter itself.
This seems to have worked for now--will let the forum know if further problems
Aug 18, 2009 | Nintendo Wii Console
TV seems to be dead
Yes with an LCD it can be dead. The life of LCD is not nearly that of a tube TV. It depends on the hours of use. Most likely time to replace it.
Good luck,
Jun 16, 2008 | Televison & Video
Protron PLTV-32 Television Logo
19 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
